Re: Out Damn (Water) Spot!
Ease of removal of water spots can depend on several factors, including whether if they're deposits (convex on top of the paint) or etchings (concave, into the paint) -- problem is, it can be hard to tell the difference.
The clay bar is a great start on removing deposits, but if another application or two doesn't work, you might also try a little white vinegar to see if it'll help dissolve them.
But if you've got water that sat on the surface and the sun hit it to cause the spots, you might have etching -- or permanent damage -- into the paint.
And really, either way, you would want to see how a cleaner wax affects it, and progressively go more aggressive if necessary to help polish out the spots -- pre-wax cleaner or scratch remover -- just be careful that you don't remove too much of the finish in an effort to remove the damage.
