Tranny Prob. 97 GMC Sonoma
lilkim81
03-17-2007, 12:25 AM
I need a little input on what to do next... My 1997 GMC SONOMA 4X4 Automatic Trans. has a trouble code of P1870 (Transmission Component Slipping) What is my next step.... It has been doing this for a while and I'm ready to get it taken care of before I have to replace the tranny. What do I do now?
MT-2500
03-17-2007, 09:55 AM
What is the service history and mileage on it?
Best to find a good repair shop that is capable of testing the transmission out to see where the problem is.
Do not go to a rebuild happie transmission chain store.
Check around and find a good shop.
It may be electrical or valve body or converter or internal damage.
Some have pcm updates and some 97 have ign switch problems.
Here is a sample of some things that can cause code 1870.
Diagnostic Information on DTC P0894 and P1870 #02-07-30-001A - (02/11/2004)
2000-2004 Passenger Cars and Light Duty Trucks
2003-2004 HUMMER H2
with 4L60-E or 4L65-E Automatic Transmission
This bulletin is being revised to include additional model years and additional diagnostic information. Please discard Corporate Bulletin Number 02-07-30-001 (Section 07 -- Transmission/Transaxle).
Diagnostic trouble codes (DTC) P0894 and P1870, Transmission Component Slipping, may have different root causes. The following diagnostic tips are provided to assist in accurately repairing the condition.
Corporate Bulletin Number 01-07-30-023A, dated November 2001, is intended for 1996-1999 vehicles with more than 32,000 km (20,000 mi). This bulletin addresses wear in the valve body TCC isolator/regulator bore, which can cause DTC P1870. This wear condition is not the cause of DTC P0894 or P1870 on any 2000 model year vehicle built after January 15, 2000, or any 2001 or newer vehicles as the valve body used on these vehicles has been revised to prevent the wear condition.
Corporate Bulletin Number 99-07-30-005, dated March 1999, should be used to help with diagnosis of these DTC's. This bulletin will help to determine if the DTC is caused by the TCC system or by a slipping internal transmission component such as a clutch or band.
Slip speeds greater than about 250 rpm at steady state driving are caused by a slipping clutch or band.
Slip speeds below 250 rpm at steady state driving are usually caused by the TCC not applying but may also be caused by a slipping clutch or band.
A plugged or restricted TCC apply fluid orifice (238, located in the pump) may cause DTC P0894 or P1870, especially in low mileage vehicles with less than 8,000 km (5,000 mi).
A converter clutch valve (224, located in the pump), which does not have full travel of 13 mm (0.5 in) or is stuck in the off position may cause DTC P0894 or P1870. Inspect the valve for chips, debris, nicks or burrs. Also, inspect the springs (225 and 226) to make sure they are not limiting valve travel. A spring that is not fully wound may catch in the bore, limit valve travel and cause DTC P0894 or P1870.
A cracked or leaking TCC solenoid (part of harness 66) may cause DTC P0894 or P1870. Use solenoid test kit J 44246 to test the operation of this solenoid.
A cracked or leaking TCC PWM solenoid (396) may also cause DTC P0894 or P1870.
When attempting to diagnose a DTC P0894 or P1870, it is important to also refer to the appropriate Service Manual for further possible causes of this condition.
lilkim81
03-21-2007, 11:07 PM
My hubby has alot of work to do. Thanks so very much, I will keep you posted.
