90' Regal Dash Removaldksram 03-15-2007, 10:20 PM Does anyone have a diagram of how to remove the DASH? The top part. I took out the screws and can't get it to budge.I just want to get the SPEED CLUSTER OUT:banghead: phildcamp 03-16-2007, 06:54 PM I have a 94 regal. I think the dash is the same. I've had the whole thing in n out several times. should be 2 fabric covered speaker grills on top of the dash (allthough there may be no speakers there at all) anyway remove the grills. look in the opening from above (outside the car) to see the screw heads. one you remove them you should be able to move the whole top plate of the dash up n down some. move it up a little n pull back towards you. it might be hard to get free, but if it moves up n down then you should be all set to remove it. phildcamp 03-16-2007, 06:58 PM oh, also be really carefull with the wire harnesses for the gauge cluster. they're pry really brittle. dksram 03-17-2007, 01:09 AM Got it.It pops out easy when you get all the screws:grinyes: .Thanks. Now I just gotta find out the diagram for the speedo and try to solder the thing.Just to see if that really works. BY the WAY, Anybody know where that post is? I can't seem to find it.Thought I seen it on here before Automotive Network, Inc., Copyright ©2012
