Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > GTI
Old 03-09-2007, 04:34 PM   #1
fullthrottle13
fullthrottle13 Normal reputation
need help on starting/idle problem
i have an 85 gti and every time i start it up it will not idle... i can press the trottle all the way but rpm's stay at 2-300 for about 10-20 seconds...then it suddenly kicks in and from there on the idle is fine and it runs great...until the next stop...i turn it off and when i restart i have the same problem...hot or cold makes no difference...in the morning the cold start will cover up this problem a little but after 3-5 minutes when the cold start valve deactivates the rpm's drop in the same way and i have to wait another 10-20 seconds until it idles fine...it drives me nuts that i can not figuer out what is wrong...what part it responsible for the first seconds after start up???...any ideas suggestions or did you have the same problem...thank you very much for your help!!!
fullthrottle13 is offline   Reply With Quote
Old 03-10-2007, 10:40 AM   #2
turbo.:R
turbo.:R Normal reputation
Re: need help on starting/idle problem
check to see if the boot coming off of the air box has a slight tear in it. i had the same year car in the day and that happened and had the same symptoms.
VERWUSTUNG FORUMS
turbo.:R is offline   Reply With Quote
Bookmarks
Google
Web AF
