Clutch pedal softens over night???
pov02
03-08-2007, 03:02 PM
This just happened last night. I drove home from school and everything was fine. Then the next morning (this morning) the clutch pedal is soft enough where I cannot put the car into gear. We filled the clutch master cylinder and pumped it like there is no tomarrow and it worked fine. Within a few hours the same thing occured. Im thinkin it might be the master cylinder itself, but I was wondering what you guys think before I run off to buy another master cylinder. Any replies is greatly appreciated.
Thanks in advance
Gohan Ryu
03-08-2007, 03:20 PM
Did you lose any of the brake fluid you just filled when it happened?
InJ3cted
03-13-2007, 12:39 PM
Check all your lines. Have a friend look at the slave cyl when you are pumping and make sure its acutating all the way. Try bleeding it.
Elouerrassi
03-24-2007, 12:28 PM
Check your lines if then are good check the nuts that connects the lines togh...... i had the same problem with my clutch and it was leaking from one of the nuts that connects the lines......
Scrapper
03-24-2007, 12:51 PM
sounds like slave cylinder blew.try bleeding it..it's on the tranny theres a bleeder on it
if you look and it's wet theres your problem.
good luck......
scrapper...
