Please Help Me!!!andywyeth07 03-07-2007, 08:27 PM I have a 1998 Grand Am Gt 4 Cylinder I have been having problems with it for about six months now. It has been running really rough. When you start it it runs rough and when you drive it runs rough. When you push on the gas while driving it barly has any powers and shakes. I have no clue on how to fix it... It probably is considering "misfiring" We have replaced: Fuel Pressure Regulator Coil Packs Coil Pack Covor Spark Plugs Spark Plug Boots Throttle Position Sensor Chank Shaft Position Sensor O2 Sensor Many Fuel Filters Tested the resistance on the fuel injectores and those seem fine Please help me! I want to drive a normal car! Ryan625 03-07-2007, 08:42 PM I'd say take it to a mechanic. crazy Jim 03-07-2007, 09:49 PM blown head gasket or bad intake/exhaust Valve. Do a compression test and leak down test and also check for air bubbles in the radiator while the engine is running. Obviously you will need to heed the previous posters advice to get these things done properly.... xeroinfinity 03-08-2007, 07:56 AM Welcome to AF andywyeth07. I think you replaced about everything except for the ignition control module. If that doesnt take care of your problems then yo might consider having a mechanic check it out. Have you checked for trouble codes? justin0717 03-08-2007, 02:24 PM if when driving has no power....possibly a plugged converter Scrapper 03-08-2007, 02:43 PM i agree on ecm and check see if converter is plugged also..good luck.. andywyeth07 03-08-2007, 06:47 PM i'm going to have a compression test ran on it soon and see what that showes, then check the converter. hopefully i can find out soon.. My check engine light was on and we got a scaner and we have fixed everything that it was scanning. and the light has not came back on for about a week now.. ZGODOHF 03-14-2007, 02:02 AM First off an easy way to check the converter is to remove the upstream O2 sesor by the manifold. Run the vehicle with it removed and if it smooths out you have your answer. A couple questions though. Does the vehicle idle and if so does it stall at idle? Does it seem to run a little better at higher rpms? I posted on someone elses question that I found a bad crank position sensor that had a low output signal. The sensor not only provides the signal for the spark, but also sends it to the pcm to be amplified and sent to the ignition control modual which then in turn also provides the signal for the injector pulse. Hope this helps. Automotive Network, Inc., Copyright ©2012
