what about programing 1995 rivi keyfobmarkmark1029 03-04-2007, 12:50 AM How about the correct procedure for programming 1995 riviera keyless door fob. I haven't been able to find the correct procedure yet. Does anyone happen to know it or where to find it?:rolleyes: HotZ28 03-04-2007, 08:53 AM Have you tried this procedure? It should work on the 95 Rivi! http://img368.imageshack.us/img368/7940/obd11pinout2ax0.jpg 1994-95 Keyless Entry Programming Procedure Note: Before entering the programming mode, verify possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases. The other transmitters will not be functional until you program the transmitters again. You may program up to 4 transmitters 1. Turn ignition switch off 2. Using a fused jumper, jump datalink connector terminal 4 to terminal 8 3. Press the Unlock button on one transmitter; doors should lock and unlock 4. If you have an additional transmitter for the car to program, repeat step three, using that transmitter now. 5. Disconnect the jumper wire from the diagnostic port. Automotive Network, Inc., Copyright ©2012
