Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Explorer/Explorer Sport Trac
Old 03-03-2007, 10:01 PM   #1
cruzin4word
cruzin4word Normal reputation
unexplained noise
Have a 97 exploer sport v6. When letting off accelerator I get a loud sound that i only can describe as like a high speed cable wench winding. Sound will stop immediately if i put foot back on accelerator. Sound does not always happen. Sometimes not for days and then sometimes it wont go away for miles when it starts. The transfer case motor is shifting when we tested it. When noise is happening it seems to pull down the tach. Other than this noise vehicle is running perfectly with no jerks, missing or other noises. There are no warning lights on such as the check engine light. The ford mecanics in town can't tell us where to look. Can you help?
cruzin4word is offline   Reply With Quote
Old 03-04-2007, 09:07 AM   #2
97explorersport
97explorersport Normal reputation
Re: unexplained noise
It sounds like the speedo cable is binding. Do you notice the indicator fluctuating when the noise is present? Look for a bind in the cable or if worse comes you'll need to take the dash apart and put some graphite or lithium grease into the cable housing.
97explorersport is offline   Reply With Quote
Old 03-06-2007, 02:05 PM   #3
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Does the 1997 use a speedometer cable, or is that an electronic speedometer like is used in 2000?
Do you ever hear the noise on a cold start or when when you turn on or off the A/C? Maybe the Idle Air Control (IAC) motor is noisy, or maybe you have a driveshaft u-joint that is binding when unloaded.
-Rod
shorod is online now   Reply With Quote
Old 04-25-2007, 11:15 AM   #4
part time mech
part time mech Normal reputation
cruzin4word
I have exactly same problem did you resolve it and how thanks part time mech
part time mech is offline   Reply With Quote
Old 04-25-2007, 01:47 PM   #5
shorod
Taurus Guy
shorod's Avatar
Try turning on your A/C with the engine at an idle and see if there is a hint of the same sound. If so, the noise is probably your IAC.
-Rod
Old 04-25-2007, 03:58 PM   #6
part time mech
shrod thanks for responding
ac no ac no change I thought maybe fan clutch but the sound but the sound decrement with rpm it does change but not incrementally I've been hearing transfer case wheel bearings but because of above statement it doesn't ring thru How about any motors such as transfer shifter motor ??
Old 04-25-2007, 06:02 PM   #7
shorod
Taurus Guy
shorod's Avatar
Do you know if your Explorer has a secondary air pump?
When you turned the A/C on, did the engine speed drop and stay there, or was there essentially no drop in idle speed? No drop would indicate the IAC is working properly.
-Rod
Old 06-13-2007, 08:09 PM   #8
EZFrank
EZFrank Normal reputation
I have a simuliar noise but its coming from inside the throttle body or intake cant figure out what it is.
[IMG]http://[/IMG]
EZFrank is offline   Reply With Quote
Old 06-13-2007, 10:35 PM   #9
shorod
Taurus Guy
shorod's Avatar
You probably have an Idle Air Control servo that is wearing out. This has been a pretty common complaint.
Try turning your A/C on at idle and see if you hear hear the noise momentarily.
-Rod
Bookmarks
Google
Web AF
