Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 03-03-2007, 05:15 PM   #1
runner97
runner97 Normal reputation
Brembo rotors
I had new dealer installed Brembo rotors installed on my 97 4Runner about 20K miles ago along with new pads and shim kit. Lately I'm noticing a little bit front brake vibration (very slight) when applying brakes. Figuring the rotors might need to be resurfaced, I took the car to a non Toyota brake shop to have this done. He said they don't resurface rotors anymore since they are made so cheaply they are very thin to begin with. Is this true??? I thought rotors would last longer than 20K. The original rotors lasted 65K.
runner97 is offline   Reply With Quote
Old 03-04-2007, 02:12 PM   #2
OzzyO
OzzyO's Avatar
OzzyO Normal reputation
Send a message via MSN to OzzyO
Unhappy Re: Brembo rotors
To be honest I don't know if the newer rotors can be resurfaced or not but I have a 94 4Runner and had my rotors replaced with Napa Parts and never had a problem since and they weren't expensive at all. 20K seems like not very much wear on your rotors, I'm no mechanic but I think they should last alot longer than that. I know mine were replaced about 3 years ago, no shimmys or shakes when applying brakes so other than that I honestly don't know what to suggest to you, sorry
OzzyO
OzzyO is offline   Reply With Quote
Old 03-04-2007, 02:17 PM   #3
OzzyO
OzzyO's Avatar
Red face Re: Brembo rotors
Forgot to mention I also had to replace my brake calipers, there the 4 piston ones and mine were making my brake pads wear out prematurely.
It could be your Brake Calipers, wouldn't hurt to have them checked, because it came down to that being the culpret with the shimmying and shaking with my brakes, the calipers were sticking and constantly rubbing against the pads causing premature wear and a shimmy. Wouldn't hurt to try.
OzzyO
Old 03-04-2007, 08:31 PM   #4
fourwd1
AF -Advisor
fourwd1's Avatar
fourwd1 Normal reputation
Re: Brembo rotors
Sounds like BS to me, I've had rotors turned in the last year or so.
Maybe they were beyond turning, but they should have said so.
- - as seen in FOUR WHEELER magazine July 06 and OFF-ROAD magazine Feb 07 - -
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
fourwd1 is offline   Reply With Quote
Bookmarks
Google
Web AF
