95 GA ignition wiring
luker78
02-26-2007, 06:27 PM
Hey guys, I'm trying to install a remote car starter on a 95 grand am and it would be much easier if I had a wiring diagram for the ignition harness.
Anyone know where I can get one? or does anyone already have one?
Thanks guys
Luc
xeroinfinity
02-26-2007, 07:25 PM
If you have never installed one of these in a Pontiac I would Highly suggest you do some research or have it done.
A chiltons or haynes manual might have what you need as far as identifying the wires. I have only done 2 installs over the last 20yrs and I refuse to mess with them any more unless its an older car without that damn passlock system :rolleyes:
I'm sure others here might be able to give you some more detailed info, as thiers been several that have had the remote starters installed.
Good Luck, and Welcome to AF!
gmack221
02-27-2007, 02:21 PM
hey xeroinfinity, wasn't the 95's pre - passlock? my 95 doesn't have it.
I would think the wiring diagrams in the chilton's manual would be all you need to find the right colors of the wires. I would probably just have it installed though, for me to put that kinda time into running wires & the trouble just doesn't seem worth it when you can get a decent one installed cheap anymore.
luker78
02-27-2007, 05:06 PM
Well I did a little research and it turns out the passlock system is on 96 and up. So the 95 I'm working on will be fine. I just need to get one of these manuals.
Thanks guys. I haven't herd of the passlock before so I'm glad I posted.
xeroinfinity
02-27-2007, 07:48 PM
You are correct Gmack.
:uhoh: My bad I was thinking wrong this morning :banghead:
But its cleared up now :D
You still will want a good manual with wire color codes,
that will make it much easier ;)
