94 ram wont idle stalls and dies when warm
dodge2500
02-26-2007, 04:06 PM
Hey i have a dodge ram 2500 5.2 that is driving me crazy. The transmission went out so i just put a new one in. I also replaced the distributor and all the parts in it, replaced the crank shaft sensor, battery, battery ends, plugs, plug wires, computer, run the plug wires just as TSB 18-48-98 said , cleaned IAC, I am at a lost if any one know of anything else please let me know. The truck when gets run about 10 miles she just starts stalling dies and wont idle
Slade901
02-26-2007, 10:04 PM
what happens when you just start the vehicle and leave it running for about 10 - 15 minutes? Does it starts to stall and die as well?
If this happens only when the vehicle is moving then it has something to do with the transmission. Probably with the TCC solenoid.
dodge2500
02-27-2007, 07:34 AM
If you let the truck warm up it still does it when you drive it down the road it gets a little worst. I went out last night and crack the truck and seen two things the coil wire has two coatings of plastic around it and it still looks like a fireworks show at front of motor and now i have got a code 37 and 32
dodge2500
04-18-2007, 07:00 PM
ITs been a while and i have just replaced thecrank sensor 2 times, 2 ecms ,2 disutbuters ,2 sets of wires fuel pump checked egr valve map sensor idel air control plugs,new battery, checked alt,. Now the truck will do it cold and warm we put a timming light on the plug wires when the truck starts to act up the timming light misses when the truck does like it is loseing fire to all eight plugs and makes the truck want to miss and then stall. Some times you could go 10 miles now we can go 30 miles but it still stalls and misses. It does it going down the road as well as parked.we tought it might be the new transmission but we unpluged it and it did not change anything. If anyone could please help me thanks
elite1msmith
06-15-2008, 01:38 PM
did u figure it out yet? im having the same problem
elite1msmith
07-08-2008, 08:13 PM
any body figure this out yet?
