Please Help
wakerider113
02-26-2007, 03:39 PM
Today i was driving to school and all of the sudden the motor dies and i coast to a stop.. I tried to start it a few minutes later and it would just barely crank.. i gave it about 15 minutes and it would just keep cranking but faster now than before. i got it towed home and immediatly came here. i read some of the posts and read about the EFI main relay so i went out and got a new one. I just replaced it and it is still just cranking.. it clicks twice and just cranks... the battery is fine and i dont no what the problem is.. Please Help..
hondacivic99sivtec
02-26-2007, 05:00 PM
have you checked your fuses? my crx did this to me. it was the fuel pump fuse.
wakerider113
02-26-2007, 05:02 PM
no but i can hear the fuel pump for the 2 secs before i try to start it..
hondacivic99sivtec
02-27-2007, 04:35 PM
have you checked ALL your grounds and fuses?
wakerider113
03-01-2007, 12:27 AM
Thanks guys but nevermind... I figured out the problem... i decided to take of the valve cover to just check up on things and noticed i was missing a timing belt.. for some reason it needs one to start...lol.. it suck cuz i may have bent a valve or two.. just did a pressure check but couldnt get an accurate reading... we'll see what happens from here...
hondacivic99sivtec
03-01-2007, 01:14 AM
oh my god. you broke the belt and didn't notice?
wakerider113
03-05-2007, 05:26 PM
it didnt make any sound or anything.. it just shut off and i through it in neutral and coasted.. i was only goin about 10-15.. got the head off sat and sent it into a guy i no... i think its just 2 bent valves..
iVteC_PoWeR
03-17-2007, 07:26 PM
JUST 2 bent valves??? a broken timing belt and 2 bent valves would make me depressed
turtlecrxsi
03-19-2007, 04:52 PM
Sorry to hear that. I broke my timing belt on my crx going about 40 and went through a few gears and then tried to start it up. I thought my dizzy took a crap on me. I had a new belt and water pump slapped on and it was good to go. I guess I was one of the lucky ones. GL
wakerider113
03-20-2007, 12:09 AM
thanks guys.. well i should hopefully have her running by tomorrow if everythings goes right..thanks again..
