how to program keyless entry for a 1998 Dodge Intrepid ES?PSORC1 10-04-2002, 04:33 PM anyone know how to program a keyless entry for a 1998 Dodge Intrepid ES? any help would be greatly appreciated. Jim martin97 11-03-2003, 11:20 AM 97 service manual says to: 1 find data kink connector under steering column. 2 turn ignition on 3 ground pin 1 upper left most pin this is the programming line. the door locks will lock then unlock. 4 press any key on the transmitter, locks will cycle to confirm if you have a second transmitter press any button, wait for lock to cycle. 5 remove ground from pin 1 6 Done, test it out By the way replacement transmitter battery is a CR 2016 Radio Shack has them. ntalekt 03-05-2004, 05:11 PM 97 service manual says to: 1 find data kink connector under steering column. 2 turn ignition on 3 ground pin 1 upper left most pin this is the programming line. the door locks will lock then unlock. 4 press any key on the transmitter, locks will cycle to confirm if you have a second transmitter press any button, wait for lock to cycle. 5 remove ground from pin 1 6 Done, test it out By the way replacement transmitter battery is a CR 2016 Radio Shack has them. I wonder if this would work with newer models.. i have a 02 SE. and the dealer didnt give me the keyless entry remote. was thinking about purchasing on online. anybody know if this method works on newer models? thanx i know there is a easy way to program ADDITIONAL remotes.. its just that INITIAL programming that i need help with. thanx Automotive Network, Inc., Copyright ©2012
