New computer?dtaylor2 02-21-2007, 03:30 PM I've posted about my 1990 3.1 before, and so most of you know what it's doing. for those of you who don't, here's what it does: it'll start and idle, and then when I give it fuel, it dies. there was a time once when I could rev it to 3000 rpms before it died, but mainly it'll only idle. Here are the things I've replaced: -MAP sensor(engine code said to) -MAF sensor(engine code) -IAC unit(thought it might be that) -fuel filter -checked fuel pressure(OK according to Haynes manual) -put in new coil packs+ignition module(a freind recommended it) -it also has new plugs and wires So, I'm wondering, could it be the ECU causing the problem? richtazz 02-22-2007, 03:08 PM If the oem service number on your ECM is 1227727, then there's a good chance it's your issue. This service number is a high failure part, and will cause random dying/no start/no power issues. Automotive Network, Inc., Copyright ©2012
