1999 Ram 1500 Reverse lights dont workbeach karlos 02-20-2007, 08:40 PM Hey I've got a 1999 Ram 1500 I purchased from a friend. As the annual state inspection is approaching, I noticed neither back-up light works. I hoped it was 2 burned out bulbs. Not so lucky. I tried to find the fuse, and no fuse under the hood seems to be for reverse lights. The only one that was close was Fog Lamp/DRL (hopefully rl standing for reverse lamp), anyway, that fuse is fine. the shift indicator for the trans does go into R when I put the auto trans in reverse. Any ideas on where I could find this fuse and how I could further diagnose the problem? Any help is appreciated! dss56 02-20-2007, 10:09 PM I think there might be a switch on the steering column under near the brake pedal the switch might be bad or not aligned correctly on the column. Also like you are trying to find a fuse it could be the fuse if there is one for the backup light good luck HEMIDAZE 02-21-2007, 07:36 PM Try to move the shifter in and out of reverse slowly to see if they come on then. It may be a switch out of adjustment. The bad news is DRL stands for daytime running lights. Automotive Network, Inc., Copyright ©2012
