Where can I find a hub locknut specialty tool???LTrain 10-03-2002, 04:12 PM Anyone know where I can find a 2-pin tool to remove my hub (wheel bearings)? I'm stuck... Thanks, Larry OffroadX 10-03-2002, 04:37 PM If you're lucky, a non-chain auto parts store might have one. Look for one spec'd for 1998+ Isuzu trucks, 1989+ Honda Passports, and Jeep J20 w/ Dana 60 axles. Or order one here: http://www.ontool.com/store/product/1382-80 That one is known to work. I found one with the above spec at a local parts store but the pins were a little thicker than the Ontool one and I had to cut them down a tad with a Dremel to make them fit into the holes on the locknut. If the pins are nearly 1/4" wide, they won't fit, if they're closer to 1/8" wide, they will. Good luck, Brent Automotive Network, Inc., Copyright ©2012
