kia sportage won't startspecialist 02-20-2007, 07:53 AM Hi to you all guys, I have a kia sportage 1998 and won't start.Engine have spark,fuel pump test good,but don't have injector pulse.It is a dohc 2.0 L automatic. thanks, specialist LMP 02-20-2007, 09:29 AM I understand you have pressure on the fuel rail and you have tried with starting fluid and it fires up for a few moments with that. Injectors are driven by ECM and the camshaft sensor is linked to that sequence. www.geocities.com/lmp4203/kiasport/injectordrivers.jpg www.geocities.com/lmp4203/kiasport/cam_crank_sensors.jpg Do you have the Check Engine light ON? LMP 02-20-2007, 09:54 AM ..and..before jumping to conclusion that cam sensor is shot, remember that connectors are known as problem items to the point KIA had sent a service bulletin (I have copy somewhere..) to the effect of cutting the wires at sensor connectors and soldering the wires instead....so as a first step, check connectors for corrosion , clean and grease... specialist 02-20-2007, 10:44 AM Yes check engine is on and get P1115 and P1117.Injectors do get 12v. thanks I understand you have pressure on the fuel rail and you have tried with starting fluid and it fires up for a few moments with that. Injectors are driven by ECM and the camshaft sensor is linked to that sequence. www.geocities.com/lmp4203/kiasport/injectordrivers.jpg (http://www.geocities.com/lmp4203/kiasport/injectordrivers.jpg) www.geocities.com/lmp4203/kiasport/cam_crank_sensors.jpg (http://www.geocities.com/lmp4203/kiasport/cam_crank_sensors.jpg) Do you have the Check Engine light ON? LMP 02-20-2007, 11:17 AM P1115 Engine Coolant Temperature signal malfunction P1117 ECT Sensor Intermittent NOt much significant....except a false reading reading like close to a short circuit could be interpreted as a high temperature..and this could lean the mixture to the point of no starting...if outside temperature is in fact cold. (I,ve experimented that as a fact). So..just to be sure, I'd disconnect the coolant sensor..an open will be seen as low temperature..asking for rich mixture ..unless there is a short in sensor wiring or salt in the connector.... As for 12V at the injectors, this is normal: (it is good to know it is there); 12V is always applied to one side of injector: the other side of injector will get its ground from the ECM, only when injection pulse is applied. Automotive Network, Inc., Copyright ©2012
