Originally Posted by seanbran84
Hi stu,
I am also looking to fit fog lights in a 51 clio expression and was wondering if you could help?
I should be able to get hold of the lights and stalk, although I am a bit confused over the loom. Do both foglights have seperate wiring/loom that go to a socket under the off side fog light space cover?
I ask this cause I only seem to be able to find one light with the loom attached.
Also can you simply replace the stalk without removing the whole wipers/lights control unit from the steering column?
Thanks for any help you can provide with this!
Sean
Sean,
the car already has the connection for the loom. you get the loom, and clip it in, then run the loom from the n/s light to the o/s light, and the wire clips to the bumper.
the loom has 3 connections.
1 to go into the connection already there.
2 to go into both fog lights.
as for the stalk. i havent got round to doing that yet.. but i think its just the case of removing the case around (behind) the stering wheel. and it just clips off and on..
let me know how you get on..
thanks
stuuuu
