Oil pick-up tube/ screen cleaning or replacement?
I've decided it's about time for me to replace my park avenue's oil pan gasket (it's always had a very slow, seeping leak). A few weeks ago I had posted about my oil pressure reading low (at 40 psi and slightly below at times) I figured that while I have the oil pan removed, I might as well either clean or replace the pick-up tube and/ or screen. I've never done this, but was wondering if anyone has any experience with doing this, or if anyone knows what the best method is to clean the screen? I'm almost positive that it's clogged up with gunk, causing the low pressure reading. The odd thing is the engine only consumes less than half a quart of oil every 3,000 miles, and the oil isn't nearly as dirty as one would think it'd be after 3,000 miles of in-city driving! Although the car has over 157,000 miles on it, I'm avoiding engine gunk additives because I've heard more bad than good about them, mostly hearing that they're really bad for different internal seals. I think a simple oil pan and pick-up tube cleaning will do. Thanks in advanced for the input!
