Mx-3 with a big problem can anyone HELP!! please
I bought it a week ago and drove well back from Sheffield to Rugby.
It starts and idles fine but when you drive it just dies, I've changes spark plugs, HT leads, throttle position sensor, crank sensor and distributor, distributor cap and rotor arm and still no joy.Is there anyone out there that can help me please.
I have had my Mx3 since Aug of last year. But for the last month it start to die on me when am at a stop light or stop sign it will stutter than shut off. I have changed the same things that you have with no luck. I cant figure it out. If you come up with a answer let me now. I will do the same.
Matt
Have you even looked at the MAP sensor right behind ur air filter expensive peice but makes a lot of issues.
I Had Issues Like That And Found There To Be A Pour Signal (vacuum) To The Mass Airflow Sensor.the Rubber Boot Between The Maf And The Throttle Body Tend To Dry Out And Crack, And When The Engine Is Idling Or Going To Idle The Vacuum Allready Is The Weakest. Let Me Know Good Luck
