Need Urgent help S10deadog 02-13-2007, 04:49 PM Hi, I have a 2000 S10 with a 4.3 Vortec, it also has the EDI ignition. The problem is that it will not start after sitting overnight. It turns over fine, just will not start. If I let it sit till late morning it will eventally start. It seems to be temperature related. I have found that when it will not start there is no power to the 12v wire at the coil. I have hooked a meter to this wire and monitored it while trying to start it, and it will show no voltage unless I repeatedly try the starter in short bursts, then suddenly the voltage shows up and it fires. I cannot find a wireing diagram that shows where the voltage should come from, or what could prevent it. Once it is started it starts and runs the rest of the day, and I mean it runs like a bear, no missing, nothing. I really need to figure out as I have to scramble for a vehicle to get to work every morning that it does not start. Thank you for any input Mike old_master 02-13-2007, 05:26 PM The pink wire runs from the ignition switch through a fuse to the ignition coil. deadog 02-13-2007, 06:07 PM The pink wire runs from the ignition switch through a fuse to the ignition coil. Thank you for the reply.So would this lead me to think that I possibly have a bad Ignition switch? again thank you Mike old_master 02-13-2007, 06:14 PM Could be ignition switch, or it could be a poor connection anywhere from the switch to the fuse, to the coil. deadog 02-13-2007, 06:24 PM Could be ignition switch, or it could be a poor connection anywhere from the switch to the fuse, to the coil. Awesome finally I am getting somewhere. To confirm, there is no sensor, relay, ect. between the switch and the coil, other than what you stated. This confirms what I suspected, but I could not find a diagram to look at. I really appreciate you helping me! Thanx Mike riptide44 02-13-2007, 06:38 PM its usually the wire connector that runs to the ignition switch in the steering column - i believe there is a tsb about that for your year. deadog 02-18-2007, 07:59 AM Well I finally was able to put the new ignition switch in Saturday. (yesterday) I had purchased it earlier in the week but needed a weekend to do it. I am happy to say you guys were right on the money. The truck started instantly this morning! Thank you very much, you guys rock! Special thanks to Old_Master for the file you sent me, that is a very handy item! Keep up the great work guys we need you! Mike old_master 02-18-2007, 12:20 PM Glad we could help you get her running. If any other problems pop up, come back and see us again. Automotive Network, Inc., Copyright ©2012
