Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Exterior/bodykits/Lighting
Exterior/bodykits/Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 02-13-2007, 02:35 AM   #1
jchc_underoath
jchc_underoath Normal reputation
'97 Accord Wheels - Help Needed!
Ok, so here's the thing. I have around 1500 bucks for a new set of rims and tire combo. I wanted to get a set of Kazera 18x7.5 inch rims wrapped in Yokohama rubber. My main concern is whether or not the tires might rub on the fenders should I have to cut the wheel hard. And, I'm guessing that I'll have to fiddle with my speedometer to compensate for the bigger tires. Anyone care to give advice or share concerns? Thanks in advance!
jchc_underoath is offline   Reply With Quote
Old 02-14-2007, 12:22 AM   #2
willimo
Sweet, sweet tiny Hondas.
willimo's Avatar
willimo +50
Send a message via AIM to willimo
Re: '97 Accord Wheels - Help Needed!
The tire size change won't really be great enough to change the speedometer reading so much that you'll even notice. Yes, the rims are much larger, but the tires will be quite a bit lower profile, so while the outside diameter will change it won't be a whole lot. And in any case, the OEM guages are so innaccurate to start with, it won't matter in the end. Fiddling with it would do nothing but break it anyhow - you'd have to change the innards completely. Not something worth doing on a 1-2mph difference made by slightly bigger tires.
As far as rubbing - someone else will have to answer. Haven't done a lot in the way of 18" on an older Honda. I reckon they'd rub some (15x6.5's rub on the inside of my fenderwell during racing and I've only 2" drop), but without lowering the car too, there should be a lot of gap still.
It ain't cool 'till your girlfriend hates it. FUSC
Supra Dyno Queen Ferrari F430 Viper Red EG Civic Twin Turbo '69 Camaro Mazda 787B
Old 02-15-2007, 05:28 PM   #3
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Greenblurr93 Normal reputation
Send a message via AIM to Greenblurr93 Send a message via MSN to Greenblurr93
my 17's rub... but im tucking all 4 tires... if the overall circumfrance says the same, it wont affect your gauges. so in theory, as long as that stays the same and the width stays the same you shouldnt rub. if they are wider.. you may rub the inside during a full turn.
Greenblurr93 is offline   Reply With Quote
Bookmarks
Google
Web AF
