95 Sentra Starting issuescaddyman379 02-12-2007, 07:18 PM Hi folks, 1995 Nissan Sentra 106,xxx miles. 5 Speed manualw/1.6L The starter does not engage at all, and I hear no solenoid click. Battery is verfied good-Everything else has power. I played with the clutch interlock switch by jigging the wires and depressing the little button while trying to start, and no go there. I hear relays clicking when I turn it from Run to start, so I assume the ignition switch is okay. I also tried hammering on the starter/solenoid while ignition was in start position, with clutch depressed, and nadda. Can you guys give me specifics on where to start? I have a wiring diagram, but it doesn't tell me exactly where the clutch interlock is located. It actually calls it a module... Thanks in advance! Automotive Network, Inc., Copyright ©2012
