Problem DieingTheBrettster 02-11-2007, 11:29 PM Hey guys my friend of mine is having a problem with his 97 blazer. He said it will die with no sign, lag, sputtering, missing, voltage drop nothing. I asked if it dies at idle and he said it does and sometimes it will die when hes driving it. Any ideas? old_master 02-11-2007, 11:39 PM We need the basics. Repair history, Mileage, SES light on? Are there any DTC's in memory? What is the fuel pressure? Does it hold? Post back with some solid data to help with diagnosis. muddog321 02-12-2007, 05:55 AM See many posts on 97 failing ignition switch which when you look it up is the connector and wiring harness in the column. In fact I have seen a tech article on many GMs in common with this and often worse when a blinker on as voltage drops to 10v at the connector so engine stalls as PCM sees incorrect voltage. Blazers hate lower than 12 volts and as an alternaor fails the gages go screwy and start swinging all over. Of couse it could be many other things in the fuel, sensor, electrical system based on age, but sorry, the ign switch is the common weak link on 97 to rule it out. TheBrettster 02-13-2007, 02:20 AM He said he really doesn't know much about the car. He probably going to do a tune up this weekend. Automotive Network, Inc., Copyright ©2012
