99Runner Starting problems99toyrun 02-11-2007, 11:56 AM My 99 4runner v6 4wd 100k miles is acting up when I try to start it on cold mornings (-10,-15 deg C) Canadian weather. The starter turns 2-3 times then it stops while all the lights in the dash are on. Usually when I try the second or sometimes the third time, the engine eventually starts. Some mornings the starter does not make any noises at all when I try it the first time, but after I try the second time it turns rather slowly and eventually the truck starts up. I had the same problem about three weeks ago and I purchased a new battery. The truck started OK all this time but now I have the same problem again. The truck starts OK during the day except when it is parked for 8 hours or more. I never liked the way the truck starts since I purchased it 2 years ago. The starter needs to turn 4-5 times before the engine starts. All my previous vehicles started at one turn (4 cyl cars). Thank you for your comments. Brian R. 02-11-2007, 04:53 PM Welcome to the AF! 1. How long a drive do you take? If the new battery solved your problem and now it's back, then it may be you are not driving the truck long enough to charge the battery. Along with this, you may have a big drain on your battery because of an accessory that is running, such as a large amplifier/stereo, etc. A high-current drain would make your alternator work much harder and longer to get the battery recharged. Starting the vehicle in the cold puts a large drain on the battery and the alternator can only put out a limited amount of current to replace that used in starting. Check your battery. If it is poorly charged, then it is likely that the alternator or alternator connections are your problem. It may also be that your alternator drive belt is loose and slipping so that you are not charging the battery as well as you could. Check the drive belt for the alternator and make sure it's tight as it should be. 2. In that respect, your alternator may be inadequate to recharge your battery. Consider having it's output checked. It may not be putting out enough juice to charge the battery quick enough to keep you going. Also, the cable from the alternator may be bad and limiting the current to charge the battery. If you find that the alternator is fine, but the battery is not well charged because you don't drive it but 10 min after you start it, you can replace it with a higher curent alternator to charge the battery faster. Again, make sure the cable from the alternator is in good shape. 3. Help your truck get started by making sure the plugs are fresh and you are using a light-weight synthetic motor oil. Dino oil gets thicker when it is older, but not synthetic. I would recommend you use 0W-20 Mobil1 or equivalent brand in Toronto in the winter. 4. A high-capacity battery is also necessary (as I'm sure you know from living up there). When you buy a battery, make sure you buy one with alot of cold-cranking amps. Maybe, your battery isn't up to the task of day-to-day starting because you didn't get one with adequate reserve capacity. 5. If the truck doesn't start right away under the best of circumstances, you may have a fuel delivery-related problem. Check your fuel filter, lines, and fuel pump to make sure you are getting fuel pressure quickly. There should be no delay in building up fuel pressure. A kink in the line, a dirty/clogged filter, or a bad fuel pump can delay starting until the pressure is adequate. The engine will not get the necessary rich mixture to start until the fuel pressure is up to spec. A rich mixture may not be available if the injectors are partially plugged. You can try cleaning them with some gas treatment or bring them to a shop that specializes in fuel-injector cleaning. 6. Check the current draw on the starter. If the starter is going bad, it will begin to draw alot more current to do the same work and drain the battery to a much greater extent than a good starter. This will make charging the battery take alot longer and wear out your battery sooner. 7. Under any circumstances, a high drain on the battery will cause a loss of electrolyte. Check the electrolyte level in your battery (all cells) and make sure they are up to the recommended level. Fill them as needed with distilled or deionized water. I have the same engine in my 4Runner and it starts reasonably quickly. It's one of those chicken and egg problems where the engine is not able to start quickly and thus drains the battery. The drained battery turns the engine over more slowly and makes it more difficult to start, which drains the battery further. 99toyrun 02-13-2007, 02:35 PM Thank you for your input Brian. I do travel a short distance to work (approx. 5 miles) and I have not been taking the truck on any long trips recently to give the battery a chance to charge. Do you think that the battery is useless now since I let it loose its charge? Also, yesterday I drove the truck to work and let it sit for about 9 ½ hours (-5C deg). When I went to start it in the evening it did not start right away but after the second or third attempt it finally did. I let the truck warm up for about 1 minute then I turn on the lights and backed up from the parking spot. When I pressed the brakes I noticed that I had no power brakes and had difficulty stopping. Luckily there were no cars behind because it took me a bit of time before I could stop it. Then I put it in Drive and everything was fine. Do you think that this is related to low battery? Also something else that I found strange: My car clock has not worked for the last 3 years (no display). Last evening when I started the truck the clock was alive again. However when I tried to set it up it died again. I did not have any problems with the brakes or anything else for that matter before with this truck. Thank you for any comments. Brian R. 02-13-2007, 11:28 PM I do travel a short distance to work (approx. 5 miles) and I have not been taking the truck on any long trips recently to give the battery a chance to charge. Do you think that the battery is useless now since I let it loose its charge? I doubt it. Take it on a 30-min drive or get it charged at a shop. See if that solves your starting problem the next morning. You will damage a battery by totally discharging it, but not by using it to a lesser extent. If the charge doesn't solve the problem, then examine some of the other possible causes I listed above. Also, yesterday I drove the truck to work and let it sit for about 9 ½ hours (-5C deg). When I went to start it in the evening it did not start right away but after the second or third attempt it finally did. I let the truck warm up for about 1 minute then I turn on the lights and backed up from the parking spot. When I pressed the brakes I noticed that I had no power brakes and had difficulty stopping. Luckily there were no cars behind because it took me a bit of time before I could stop it. Then I put it in Drive and everything was fine. Do you think that this is related to low battery? No, if it happens again, have someone check your brakes. Until then, back-up carefully. Also something else that I found strange: My car clock has not worked for the last 3 years (no display). Last evening when I started the truck the clock was alive again. However when I tried to set it up it died again. I did not have any problems with the brakes or anything else for that matter before with this truck. The clock is unrelated. Get the starting and (if necessary) the brakes fixed first. Hopefully, the braking problem was a one-time happenstance and nothing to worry about. Post any further responses by replying to this thread. Don't create a new thread to respond to this one. Automotive Network, Inc., Copyright ©2012
