2000 Explorer AWD Trans Rumbling
Glacier64
02-07-2007, 03:39 PM
Have the 2000, AWD, V8, Limited. About 50% of the time when the trans goes into overdrive, there is a rumbling coming from what I assume is the transmission. Occasionally, when this happens, the radio momentarily loses power. Any thoughts? Thanks in advance.
ETA: 165,000 miles, trans has never been serviced.
MT-2500
02-07-2007, 06:13 PM
Welcome on your first post on AF.
Strange on radio losing power.
I would be looking for a electrical problem there.
Any check engine lights or codes?
What engine and transmission?
Glacier64
02-08-2007, 12:59 PM
I have the 5.0 V8 engine
4 speed overdrive automatic transmission.
No codes or check engine light
I only mention the radio as it only loses power when the transmission rumbles, but not all the time.
MT-2500
02-08-2007, 03:05 PM
A am not sure on what it could be but it would be a good idea to get it in and have it checked out.
Good Luck
MT
shorod
02-08-2007, 09:02 PM
If this were happening on a Taurus, I'd suggest you check the Digital Transmission Range (DTR) switch. They have been known to cause some very interesting electrical issues, including some with the radio. However, I haven't seen where that's such a common occurance on the Explorer.
You may want to search this forum though for "transmission range" or DTR.
-Rod
shorod
02-08-2007, 11:11 PM
Looks like the explanation on the Taurus is because the power for the Rear Control Unit is provided through the DTR switch. No such circuit on the Explorer from what I can tell.
-Rod
