Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Dakota
Old 02-06-2007, 09:08 PM   #1
dsthomspson1
dsthomspson1 Normal reputation
98 dakota rear end noise - ring and pinion?
I have a 98 dakota with 318 engine with 140,000 miles. Lots of rear end noise almost a grinding noise but definitely a VERY audible whine. I think it's probably the ring and pinion that needs replacing. The noise is only under acceleration and constant speed. Starts at 15 MPH and goes all the way up. No noise on coast. Anyone ever change these themselves or is this a job for an experienced shop?
dsthomspson1 is offline   Reply With Quote
Old 02-06-2007, 09:21 PM   #2
corning_d3
corning_d3 Normal reputation
Send a message via Yahoo to corning_d3
Re: 98 dakota rear end noise - ring and pinion?
That sounds like the differential going south. There are a few tools you'll most likely need. You'll also need to have some knowledge about pinion bearing preload specs, and how to properly shim the differential case, etc. I think a good chiltons or haynes manual should point you in the right direction if you choose to do it yourself. If you want it to last a long time, however, I'd suggest taking somewhere where you trust the mechanic/technician.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
corning_d3 is offline   Reply With Quote
Old 02-14-2007, 07:16 PM   #3
kinetica7
kinetica7 Normal reputation
dont forget about the U-joints, although they usually make more of a squeaking sound
kinetica7 is offline   Reply With Quote
Old 09-18-2007, 04:11 PM   #4
sessy1979
sessy1979 Normal reputation
I also have a 98 dakota with the same rear end whining noise. only does it when you accelorate. someone told me it was the rear axle and bearings. how costly can it be to have someone else do the work?
sessy1979 is offline   Reply With Quote
Bookmarks
Google
Web AF
