95 riviera engine swap question!
Marialyce
02-06-2007, 05:28 PM
My son has a 95 Riviera with a bad engine, super charged,. Can he swap for an engine that is not super charged or does it have to be super charged? Thanks!~
dreww
03-30-2007, 11:58 PM
I dont think you can just swap it. The s/c riv's has different PCM's and the fueling tables and such are all different. The NA motors also run higher compression.
probably and electrical nightmare, find another 95 S/C motor.
GSXMEN
04-06-2007, 04:07 PM
The changeover to NA 3800 would be more hassle than it's worth.
Where are you located? A friend of mine is parting out 2 - 95 Rivs and I know where a 3rd good engine is.
I'm in Binghamton, NY 13901.
BTW.....is it just the bottom end of the engine that's bad? I could give you a quote on the whole engine or basic long block. Thanks
Scott
bobfrompips
06-19-2007, 12:14 AM
Are those motors still available?
GSXMEN
06-19-2007, 12:18 AM
Last time I talked to him, he still had them both.
I'll see if I can find out more specifics.
I know at least one of them is a higher mileage engine. At the very least, they are complete and would be excellent cores to rebuild.
bobfrompips
06-19-2007, 12:22 AM
Thanks Scott. My '95 has only 96k, but a rebuild would be more expensive than a swap. Will any other year fit the '95 s/c?
bobfrompips
06-19-2007, 12:24 AM
Thanks Scott. My '95 has 96k, but a rebuild is more expensive than a swap. Will anything else fit a '95 s/c?
GSXMEN
06-19-2007, 12:26 AM
If you were just looking for a SC, you could also get a 94 SCer.
The 92-93 are paired together, then the 94-95.
For a bit more performance on the 94-95, you can get the smaller pulley from a 92-93 to get more boost.
bobfrompips
06-19-2007, 02:49 AM
Scott. you're great. But '95 scers are scarce..moreso '94s. Will any non sc's fit? I love this car and really don't want to lose it. Next step would be saying goodbye. Almost new inside & out.
scoopy03
06-19-2007, 10:04 AM
up here in new jersey i see 95 rivieras all day long :p :p :p
scoopy03
06-19-2007, 10:07 AM
one you the sc 3.8 has a lower intake manifold especially for the supercharger to bolt up the lower blocks are the same iirc. the sc 3.8 has a different PROM than the non sc 3.8's do.
GSXMEN
06-21-2007, 12:13 AM
Finally got in touch with my friend with the Rivs.
I'll send you a PM.
