cruse control & hornurasula 09-30-2002, 04:16 PM hi guys, my cruse control and horn is not working. could it be a blown fuse? if so, where r the fuse for them located? Thanks! boingo82 10-02-2002, 04:09 AM I don't have my FSM on me right now, so I can't look it up, but there is a fuse panel right in front of your left knee (assuming you're in the driver's seat) and it should tell you what fuse is what inside the lid. Hope this helps. Emily rockola 10-03-2002, 12:08 PM For no cruise AND horn button I suspect you have a bad switch inside the steering wheel. Some manufacturers (like GM) call this part a "clock spring". I don't remember what Nissan called it. I had this exact problem a few years ago on my 92 and, if I remember correctly, I took off the steering wheel horn pad/cover and replaced the CENTER clock spring switch. I'm sorry I can't remember more details regarding specific disassembly or the cost. ($50 -$65 me thinks) Check a Haynes if you got access to one. If you mention "center clock spring" to your parts guy along with the malady he'll probably get your meaning. Hope this helped! Automotive Network, Inc., Copyright ©2012
