Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 02-03-2007, 04:26 AM   #1
mrflint
mrflint Normal reputation
Question Low Trac Light
My 1998 Lumina recently has blue light coming on that says LOW TRAC.
Its been coming on more frequently and now it comes on every time I drive, It goes out after a few minues. The equipment list on this car does not list traction control.
Is this traction control and how do I fix it?
mrflint is offline   Reply With Quote
Old 02-03-2007, 06:16 AM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
jeffcoslacker Normal reputation
Re: Low Trac Light
That's indicating the ABS is activated, seeing a discrepancy in wheel speeds. Do you hear the ABS chattering when you brake?
My guess is you have a wheel speed sensor fault.
jeffcoslacker is offline   Reply With Quote
Old 02-03-2007, 09:40 AM   #3
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Low Trac Light
You need to get it on a good professional scanner and look for ABS and transmission code.
Post back code no.
MT
MT-2500 is offline   Reply With Quote
Old 02-03-2007, 10:19 PM   #4
gw84
gw84's Avatar
gw84 Normal reputation
Send a message via MSN to gw84
Re: Low Trac Light
I'm pretty confident that these vehicles DO NOT have traction control as the light may lead you to believe. I believe that's an option that just recently became availiable. In my opinion, the LOW TRAC light is pretty useless. I've seen it come on when the tires slip a bit such as while driving on loose gravel
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 02-04-2007, 06:33 AM   #5
jeffcoslacker
Re: Low Trac Light
Like I said, it's just letting you know the ABS system has seen a difference in wheel speeds, and is in ready mode....I think it is also useful as a warning...say you were driving on the highway on what you thought was just a wet road, when it suddenly becomes black ice...the moment a drive wheel slip began, that light comes on and you realize something bad is about to happen, way before you'd hear the engine begin to overrun and you've already broken traction and are now in danger of loosing control of the car if you do anything sudden...
Also lets you know when your struts are shot...when you start seeing a lot of that light when braking on crappy pavement
Old 02-04-2007, 09:06 AM   #6
gw84
gw84's Avatar
Re: Low Trac Light
I retract my earlier statement
Old 02-04-2007, 09:43 AM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Low Trac Light
If light is on there is a problem and it should be checked out.
May not pertain to a 98 or newer ones but on older ones I have found transmissions problems or transmission codes will also trip the low trac.
If light is on there should be code/codes somewhere.
Needs to be checked out.
MT
Old 02-06-2007, 12:17 PM   #8
bleepster
bleepster Normal reputation
Re: Low Trac Light
'97 lumina here - mine comes on when tires lose grip. like when i try to stop and hit ice and slide a bit.
The light illuminates in BLUE.
I was under the impression that if there WAS a problem, the light would illuminate in AMBER/ORANGE or RED (I.E. Low Oil Pressure, Low Coolant, Security, Volts, Etc..)
If it was ABS related - wouldnt the ABS light come on???? (which is amber/orange by the way)
bleepster is offline   Reply With Quote
Bookmarks
Google
Web AF
