its happein again
tauruschick
01-29-2007, 10:32 AM
new problem my car is gettin codes 420,301,1400,430 can anyone please help
ilLUMINAteddriver
01-29-2007, 12:18 PM
420, 430 are both "catalyst below threshold" for banks one and two, so I'm guessing that means a problem with the catalytic converter. Get that checked.
1400 I can't find, but I'm sure someone here can help you out. If it's 0400 it's a problem with the EGR system.
301 is a misfire in the #1 cylinder, which could be related to the problems with the catalytic converter(s). If you have a duratec engine (DOHC), you'll have two cats to go with the two exhaust pipes, unless I'm dearly mistaken.
Good luck.
shorod
01-29-2007, 11:29 PM
What year is your Taurus and which engine do you have?
-Rod
shorod
01-29-2007, 11:39 PM
From your Private Message I see you have a 1996 wagon.
Per the factory service manual, Diagnostic Trouble Code (DTC) P1400 indicates that Self-Test has detected a DPFE SIG circuit input below the minimum.
Possible causes:
-- Leaking upstream pressure hose.
-- DPFE SIG shorted to GND or SIG RTN.
-- VREF shorted to GND or SIG RTN.
-- Damaged D.P.F. EGR sensor.
-- Damaged PCM.
The DPFE has been a rather common issue with the Taurus and would effect both cylinder banks. This might be a good place to start.
A misfire of cylinder #1 would typically only effect bank 1.
-Rod
