96 grand caravan 3.3 wont starttony2tx 01-28-2007, 09:03 PM well....i got one 96 grand caravan 3.3...that wont start...i run the selft test and i found two codes...17 andn 54...i replace coolant, cam and crank sensor and still wont start....any help will be appreciate....thanks.....:iceslolan RIP 01-29-2007, 09:42 PM Still getting codes? Getting spark at the plugs? Is it getting fuel? Can you hear the pump? I take it the starter is cranking the engine but, no start correct? Was there any maintenance done just before this problem started? tony2tx 01-29-2007, 11:12 PM yes i hearthe pump, i dont see spark, the codes are 17 and 54 i got them with the dash ligth...replace cam, coolant and crank sensor.... tony2tx 01-30-2007, 12:40 AM yes i hearthe pump, i dont see spark, the codes are 17 and 54 i got them with the dash ligth...replace cam, coolant and crank sensor.... now i found that i dont have power on any of the wires at coil .... Automotive Network, Inc., Copyright ©2012
