Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 01-28-2007, 04:00 PM   #1
dderolph
dderolph Normal reputation
Temp gauge stays all way to right, even when off, when cold
As stated in the title, the temp guage needle does not move; it stays all the way to the right, which would normally indicate overheating. It stays there all the time; never moves. I'm wondering the cause of this is a faulty temp guage or a faulty senser on the engine block.
I believe it has nothing to do with the thermostat. But, driving this way is surely not good because we don't have an accurate temperature reading. So, if the engine was, in fact, running too hot, we would not know that.
dderolph is offline   Reply With Quote
Old 01-28-2007, 10:56 PM   #2
AudioGuy93DelSol
NA is Best!
AudioGuy93DelSol's Avatar
AudioGuy93DelSol Normal reputation
Send a message via AIM to AudioGuy93DelSol
Re: Temp gauge stays all way to right, even when off, when cold
Are you throwing any codes?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
AudioGuy93DelSol is offline   Reply With Quote
Old 01-28-2007, 11:50 PM   #3
dderolph
I should have mentioned this is a '92 Integra. I'm not aware that it ever "throws any codes". I'm not thoroughly familiar with the car; it belongs to my son. I drive it occasionally. The engine warning light does not come on.
Old 02-01-2007, 02:40 AM   #4
808hardbody
808hardbody's Avatar
808hardbody Normal reputation
maybe the gauge went bad. I think you can count the codes on the ecu. There is red led light that flashes. Don't quote me on that.
________12.5....5psi. nuff sedd ___________
808hardbody is offline   Reply With Quote
Old 02-01-2007, 09:56 AM   #5
dderolph
I presume ecu means Engine Control Unit. And, I'm sure getting readings from it require an electronic diagnostic or monitoring device to be connected to the engine. Obviously, such devices are normally only owned by service shops. So, without taking the car to a shop, I have no way of getting any reading of any codes.
My reason for posting the question in the forum was to see whether anyone knows what the cause of the erroneous guage reading might be, without taking it to a shop.
Old 02-01-2007, 09:02 PM   #6
808hardbody
you don't need a monitoring device. Lift up your passenger side rug and count the led light on the ecu.
Old 02-02-2007, 12:57 PM   #7
AudioGuy93DelSol
NA is Best!
He has a 92 so it's no OBD-0, it's OBD-I and the procedure for checking codes can be found here.
Bookmarks
Google
Web AF
