Electrical lights flashinghawk88032000 01-28-2007, 02:49 PM Here is the problem I am having. a while back battery went dead. So I replaced with a new one. Now ever since then, the climate control lights are always flashing. And the a/c and the heat still work. But lights still flash. Any clues. Bernard Feltzer 01-28-2007, 03:33 PM there is a re programming sequence you have to perform pushing in the ac and heater buttons, it is somewhere in one of these previous posts. hawk88032000 01-28-2007, 04:01 PM Thanks for the response will look for it. hundahunta 01-28-2007, 06:14 PM TO INITIATE TESTS: Set Blower motor ON HIGH Set Mode position to Panel Open all A/C outlets Set Temperature to Cold (Both slide pots if equipped) Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light) RESULTS: All LED's will turn on for 5 Seconds Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing. Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit. After all tests have passed, Calibration Diagnostics and Cooldown can be run separately. COOLDOWN TEST ENTRY TO INITIATE TESTS: Set Blower motor ON HIGH Set Mode position to Panel Open all A/C outlets Set Temperature to Cold (Both slide pots if equipped) Depress WASH and A/C simultaneously for 5 Seconds NOTE: Prior to start of test, If the evaporator is already cold, the system will fail test. To correct, operate system with A/C OFF and the blower motor ON high for three minutes prior to starting test. RESULTS: All LED's will turn on for 5 Seconds Cooldown Test is running when A/C and RECIRC. are alternately flashing. If A/C and RECIRC. are flashing simultaneously, Cooldown has failed. CALIBRATION DIAGNOSTICS AND COOLDOWN ABORT Test can be aborted by doing one of the following: Depressing Rear Window Defogger, RECIRC and Rear Wiper buttons. Cycling Ignition OFF and then ON. Control will automatically abort after 15 minutes from the time Calibration Diagnostics and Cooldown was entered. The HVAC control module will return to normal operation or may indicate unsuccessful Calibration Diagnostics or Cooldown test by LED's flashing simultaneously. hawk88032000 01-28-2007, 06:24 PM Thanks for the help will try it out. Automotive Network, Inc., Copyright ©2012
