Well, I couldn't find the OBD 'pin jumper' reset method, but apparently another way works, but I don't know as I haven't tried it myself.
Disconnect both battery cables for approx 5 mins. and connect each battery cable together, turn on your hazard/warning lights, after 5 min's reconnect the battery. This will clear the memory and all codes and should reset the engine light.
After you go about this reset, drive lightfooted for about 3 hours or so as the computer has to relearn your driving style. If you are aggressive, it supposedly learns your aggresive behavior and adapts to that. If your a granny foot, it'll learn your granny footed ways.
Hope this helps...
