Fog Lights Wont Workjc_stylz 01-25-2007, 03:12 AM I just bought some OEM foglights for my 95 civic hatch.. did installation and erthing.. ddnt work.. i changed bulbs relay and fuse and still no work.. what do i gtta do to get the lights to work????:banghead: AudioGuy93DelSol 01-25-2007, 05:42 PM Are they hooked to a good 12 volt source? Grounded properly? jc_stylz 01-26-2007, 09:21 PM yea they are. me and my friend have been trying to figure this one out.. they are hooked up to the board under the steering wheel but there is no wire that goes straight to the battery.. do u think it could be a fuse from the board? AudioGuy93DelSol 01-26-2007, 10:20 PM Do you have a multimeter? Check for 12v along the circuit. Also, when you turn them on, do you hear the relay click? jc_stylz 01-27-2007, 08:34 PM yea the relay clicks when i hit the switch. The light on the switch goes on too when i turn it on. SILVER2KCIVIC 06-03-2007, 09:16 AM :grinno: HEy make sure u got good grounds bare metal where u grounded the grounds I had twO grounds on my kit one ground coming off the right fog light witch I forgot to ground to a ground scew on the bumper an mine did not work till I did so . An there nother ground under the dash coming off the switch wiring harness that gos to the switch that I grounded under the dash to a factory ground scew ..:rolleyes: Automotive Network, Inc., Copyright ©2012
