2001 dodge caravan sport
shaws5
01-24-2007, 10:19 PM
passenger window will go down but will not come up unless you open passenger door and slam it then it might go up and then again maybe not i am gessing it is the drivers door switch but you other owners might know more than me!!!
hundahunta
01-25-2007, 07:49 PM
window regulator!!!!!!!!!!!
Mrbizness1
01-25-2007, 08:49 PM
Could be a broken wire that goes into the door through the front jamb. open the door and look for the wires that go into it the door, they usually will be wrapped together in black covering. Try to squeeze or twist it while operating the window switch. If this is the problem area use a razor blade to open the covering to locate the wire.
Good Luck
