Keep stalling while driving.
rcdldl
01-24-2007, 01:21 PM
I have a 97 plymouth voyager, 3.0 v6, 120k. It starts up fine and drive's o.k. but when I take my foot off of the gas pedal it stalls. As long as I am pushing on the pedal while in D it doesn't stall. When it stalls I need to put it in N and start it while given gas for it start back up. It is very cold here and when this problem first start I had almost no gas. Since then I have put gas in the van along with dry gas and fuel injector cleaner. Fixed a vacuum hose and cleaned out the egr valve. ANy ideas while be helpfull.
RIP
01-25-2007, 12:07 AM
The Idle Air Control (IAC) valve controls idle speed. It will give you a Service Engine light (SEL) and set a fail code in most but, not all fail modes. I would first check for fail codes and see what you come up with. For more specific codes you can go to Autozone where they will connect a scanner and check for codes free. For general codes you can turn your key from off to on three times, leaving it on and count the flashes of the SEL. A code 21 would be flash, flash, pause flash. Code 12 and 55 are normal. All codes are 2 digits.
Codes or no codes I would remove and clean the IAC valve and it's port in the throttle body. While you're at it clean the throttle body with a spray cleaner. Cheers.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1a/3f/ba/0900823d801a3fba.jsp
rcdldl
01-25-2007, 07:23 AM
Thanks for your help RIP. The link you have is just what I needed to see.
rcdldl
02-01-2007, 11:23 AM
Fixed. Cleaned out the IAC valve and throttle body adn it fixed the problem
RIP
02-01-2007, 01:06 PM
Glad to hear you've tamed the beast. Thanks for posting the fix. Cheers.
