Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > BMW > 6 Series
Old 01-23-2007, 04:41 PM   #1
joshdkline
joshdkline Normal reputation
Please help 633csi
I have a 1984 633csi. Just had the heating core replaced. Car came back with the temp guage not working-- 2 days later the battery was dead. Charged the battery and tightened loose battery cables-- temp guage started working. 2 days later-- dead battery. Charged and tested battery and system-- everything checked out ok. 1 week later-- dead battery. Replaced battery-- temp guage does not work again-- 2 days later the battery is dead again.
Any thoughts???
joshdkline is offline   Reply With Quote
Old 02-07-2007, 01:43 AM   #2
infinity0202
infinity0202 Normal reputation
Re: Please help 633csi
sounds like a similar problem I'm having with my prizm. the battery is dying for no apparent reason and I'm not sure why.
I need to check some more things on it and if I have any ideas I'll let you know, likewise if you find anything thats easy to check that helps you out let me know
infinity0202 is offline   Reply With Quote
Old 02-18-2007, 08:32 PM   #3
roadmaster1955
roadmaster1955 Normal reputation
I have the same issue with my 633 (a 1984 as well). The battery is dead after 3 days. I did not find the the problem.
Your help guys will be very usefull.
Thanks
roadmaster1955 is offline   Reply With Quote
Old 03-03-2007, 09:34 PM   #4
emeryk
emeryk Normal reputation
I have a 1984 633csi that needs charging if it sites for more than a couple of weeks.
Again any thoughts appreciated
emeryk is offline   Reply With Quote
Old 03-13-2007, 01:24 PM   #5
NJ Gabe
NJ Gabe Normal reputation
Send a message via AIM to NJ Gabe
First of all, if you let a BMW sit for about a week, it will need to have the battery charged up. I have a friend that has a '06 330ci that her battery kept dieing on her. The dealership told her that she has to drive the car for 1/2 an hour once a week or the battery will continue to die. She hasn't had any more problems since. Your battery problem could have to do with a current draw when the car is off. You will need to use a test light connected between the positive battery terminal and the positive cable end. If the light goes on, you have a current draw. Check to see that your glove box, trunk light, interior lights go off when you close the door/ trunk. I hope this gives you a place to start.
NJ Gabe is offline   Reply With Quote
Old 03-16-2007, 03:06 PM   #6
ec437
ec437's Avatar
ec437 Normal reputation
This isn't true at all. I've let my BMW's sit for up to a month (maybe more) at a time and they start right up.
The OP didn't ask about an '06 3 series. They asked about a car that is 22 years older and significantly different. Whatever the dealer told your friend about her car is really not that applicable to this 6 series IMO.
All that said, yes, check your current draw. Also check your alternator (carbon brushes in particular) and maybe grounding points. Stuff like that.
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
ec437 is offline   Reply With Quote
Bookmarks
Google
Web AF
