Re: water sound
Just drain all the coolant and it will go away. Joking of course.
Might try replacing the radiator cap and make sure the seal area in the fill hole is smooth and clean.
then keep your overflow reservoir at it's proper levels so it will self burp the air out over time.
as he said some noise will always be present, it's a question of how much air is in the system.
Does your heater make hot ALL the time or just when you rev the motor?
This would be indicative of low coolant.
