1988 K1500 4.3 V-6 engine knock
wolfden6
01-20-2007, 11:10 PM
I have a 1988 K1500 with a 4.3 V-6.
It has developed a knock in the engine, it does not knock when cold, only after the engine has reached full operating temperature.
It does not knock when under acceleration and only when at highway speed when you just barely give it throttleis it present. When you decelerate or under moderate acceleration it does not knock.
It is very faint when at a idle.
Thanks for any help in diagnosing this knocking noise.
Blue Bowtie
01-21-2007, 11:20 AM
Since you have an '88, it should be a TBI. There is a timing advance bypass connector under the hood. After the engine is at normal temperature, disconnect this connector and drive it under the same conditions to see if the noise repeats. Running the engine in this mode will set a 42 error code, but you can clear that after the diagnosis.
If the noise does not occur with the connector removed, you may need to check the EST system, including the detonation sensor. You may also need to decarbon the chambers, and check EGR system operation.
If the noise still occurs with no timing advance, there may be mechanical problems.
wolfden6
01-21-2007, 03:07 PM
I unplugged the advance bypass connector and drove it and the noise has disappeared.
Does this mean that the ignition has to much advance?? or does it mean that the knock sensor is bad??
I checked the timing and it is dead on .
Any other help would be appreciated.
Thanks
mbumgua
01-21-2007, 10:20 PM
check knock sensor-probably needs replacing.
wolfden6
01-21-2007, 11:57 PM
what parts exactly does the EST system consist of??
Also what is the best way to de-carbon the combustion chambers (short of removal of cylinder heads)
Thanks for everyones help
wolfden6
01-23-2007, 09:45 AM
Also where is the knock sensor located on the block(which side) and does it just screw into the block and are there any other sensors that comprise the EST system??
Also what is a good fuel additive that will help reduce carbon in the combustion chambers
Thanks
mbumgua
01-23-2007, 10:08 AM
Look right above the oil pan on lower passenger side of block. It is screwed into the block right above the oil pan. You have to sqeeze the ears of the connector to remove it. Possibly you could have a loose wire. A quart of Mavel Mystery oil or a can of Seafoam poured into the tbi or injected via a vacuum line will clean up the carbon. Also you can add a quart or can to a full gas tank.Also I have used a gallon of diesel to a full tank of gas for cleanup and lubrication.Water injection into the tbi thru a vacuum line with engine running will also clean up carbon. Chevron and GM also make a top end cleaner that you spray into the tbi with engine running. This spray cleaner is the same stuff sold by Gunk as engine degreaser(the non-foaming kind).
wolfden6
01-27-2007, 09:42 PM
Where exactly on the block is the knock sensor on a 1988 4.3 V-6??
I looked on the passenger side of the block just above the oil pan and did not see one.
Would you have to remove the starter to get to it??
I retarded the timing back and the knock stopped, but it seems that it has lost some power due to this adjustment.
If the knock went away after I retarded the timing would that point to the knock sensor being bad or should I look elsewhere for the problem??
Any help would be appreciated
Thank you
wolfden6
01-30-2007, 12:28 AM
Ttt
mbumgua
01-30-2007, 01:26 AM
carbon in cylinder=hot spots = preignition =knock. Try decarbonizing as your next step. Sounds like knock sensor is ok.
wolfden6
01-30-2007, 09:41 AM
I already de-carboned the cylinder with GM top engine cleaner and it still knocked.
The only way to get the knock to stop was to retard the timing (WITH the ESC connector CONNECTED) back to TDC and now the knock is gone. Would that point out that the knock sensor is good and that I should try to de-carbon again. The pickup just turned 200,000 miles and could it need another round of top engine cleaner.
Also when I used the GM cleaner it did not smoke as bad as when I have used Seafoam in the past, does Seafoam work better or just produce more smoke in the process.
I am going to readjust the timing as there is a noticable drop in power with the timing set at TDC with the ESC connector connected.
Anyone have any other ideas and also where on a 1988 V-6 is the knock sensor located because I look on the block on the passenger side and all I saw was the starter, is it above the starter and accessanle without removing the starter??
Thanks for all the help!!
mbumgua
01-30-2007, 11:53 AM
On most chevy engines there are plugs (block drains) in the block just above the oil pan. Chevy replaced one of these with a knock sensor, usually on passenger side of block. Because of starter on v6, these were placed on driver side of block and sometimes in later models they have one by the distributer about 2 inches from oil pressure switch. Have you checked egr passages for carbon buildup?
wolfden6
01-30-2007, 08:58 PM
No I have not checked the EGR passages.
Do you just remove the EGR valve and clean the passages behind the valve??
Any particular cleaner to help clean the carbon off??
Thanks
mrbee
01-31-2007, 06:15 AM
Just drive it till it blows up.... lol
wolfden6
01-31-2007, 09:28 AM
HA HA You are sooooo funny
mbumgua
02-01-2007, 11:21 AM
EGR has to be removed to clean passage. Sometimes you have to chip out the carbon. If you have the manifold off and access to a bead blaster you can clean it and the rest of the manifold easily. But this requires careful cleaning to get all glass beads out of the manifold.
wolfden6
02-05-2007, 10:12 AM
While driving it finally set a trouble code of 43 which my book says is a problem with the spark control system. which should I check the knock sensor or the ESC module. I looked on the back of the engine and all I found there was what looks like the oil pressure sending unit and I can not find the knock sensor there or on the right hand side of the block above the oil pan, would it be under the starter?? I have looked all over for this thing and I can not seem to spot it, can anyone help with the location of it specific for a 1988 4.3 V-6??
