what could have caused my 96 cirrus from not startingTalon69 01-18-2007, 06:33 PM 96 chrysler cirrus 2.5 V6, So 2 days ago the car ran fine, yestarday -12 here and the car would not start, all it would do is spit and sputter while you crank it over. So i decided to go get some plugs thinking i flooded it. I only changed the front ones for now because you have to take the upper intake off to change the back ones. So i get back with the new plugs, before doing anything i decided to put a charger on while i did the plugs, i changed the front plugs and cranked it over now i get no spark at all!! Only 2 things i did was change front plugs and hook a battery charger up and now no spark. There is no coil it has a distributor. Everything is plugged in, fuel pump is working fine, Oil level is perfect. What the hell could have happen in just by changing plugs? Talon69 01-20-2007, 12:49 AM wow its dead here, i will post in eclipse forum where i know everyone there twistedtech 01-20-2007, 02:51 AM Off the top of my head,crank sensor.I have not seen the car so I will not say for sure. twistedtech 01-20-2007, 02:55 AM Eclipse?Missed that part.I have a 95 Sebring with a 2.5.Got it to replace the 93 Mitsu I had imported to Canada before that hotrod was ever here.I miss that car. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
