Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 01-17-2007, 11:01 PM   #1
welterdesigns
welterdesigns Normal reputation
96 safari abs light
My abs light came on. the wires to the sensors on the front wheels are in tact. I read that there is a rear one. Could that be the problem? My wife baja-ed through a ditch right before this happened. Maybe a loose connection or broken wire somewhere underneath?
welterdesigns is offline   Reply With Quote
Old 01-18-2007, 04:52 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: 96 safari abs light
When the ABS lamp is illuminated, the ABS portion of the brakes is inoperative. Provided there are no problems in the service brake system, they will still operate. The ABS system on your vehicle uses a wheel speed sensor on each of the front wheels. Hydraulic pressure to each wheel is controlled independently of the other when the ABS activated. The rear wheels use one common sensor; it is also used for the speedometer. When the ABS system detects either rear wheel is locking up, it controls hydraulic pressure equally to both rear wheels simultaneously. If the speedometer is functioning properly, the sensor is working. Check the obvious first, fuses. If the fuses are ok, it will require the use of a scan tool to retrieve the DTC, (Diagnostic Trouble Code) to diagnose the problem.
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
