99-03 Grand Am Parts: Head lights/Cooling System/Engine/Trans/Ignition Systxeroinfinity 01-17-2007, 10:48 PM This will be a work In progress, as thier are more then 1000's parts for this Models of Grand Am's. Starting Up front , covering most of the usuall stuff for right now. This section also has ignition system/electrical components. http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/HeadlampAssy.jpg 1 Head light assy -99-03R GM# 22572208 - 99-03L GM# 22572207 8 Head Light Bolb - 99-03 (9007) GM# 16524431 9 Parking lightbulb - 99-03 (194) GM# 9438068 10 Signal lightbulb - 99-03 (3157) GM# 12450182 11 Side marker bulb - 99-03 (194) GM# 9438068 12 Head Lamp retainer Ring -- 99-03 -- GM# 16524656 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/Foglampassy.jpg 1 Fog Lamps Assy - 99-03R GM# 22613881 - 99-03L GM# 22613882 2 Fog lamp Bulb - 99-03B GM# 12450143 3 Fog Light Relay - 99-03 GM# 15393412 Blower Motor & Fan http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/Blowermotorresistor.jpg 1 Blower motor - 99-02 GM# 52474449 2 bracket - 99-02 52477029 3 Impellar - 99-02 GM# 52477699 4 Resistor - 99-02 GM# 15359314 5 Upper housing - 99-02 52473182 6 Lower Housing - 99-01 52473182 - 02 -- *parts included in upper housing 2.4L cooling sytem http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/waterpump2.jpg 1 Water pump - 99-01 GM# 24577255 2 Gasket set - 99-01 GM# 24574155 3 WP cover -99-01 GM# 24575938 Ignition System 2.4L http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-5.jpg 1 Cover - 99-01 GM# 10488727 2 Ignition Module - 99-01 GM# 10487716 3 Harness - 99-01 GM# 10486200 4 Ignition Coil - 99-01 GM# 10457109 10 PCM - 99 GM# 9356459 - 00-01 GM# 9356249 -bracket - 99-01 GM# 22657999 2.4 Electrical -Alternator 2.4L - 99-01 GM# 10464423 -Starters 2.4L - 99-00 GM# 10465386 - 01 GM# 10465553 AC Compressor 2.4L - 99-01 GM# 1135439 2.2L Cooling system http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/Waterpump2.jpg 1-Water Pump -02-03 GM# 24467301 2 -Gasket set -02-03 GM# 24439799 3 -Plug -02-03 GM# 90537623 4 -WP Cover -02-03 GM# 90537266 Ignition System 2.2L http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-6.jpg 1 Ignition Module - 02-03 GM# 12569276 2 Spark Plug - 02-03 GM# 25337472 3 PCM - 02-03 GM# 12210553 4 bracket - 02 GM# 22666353 - 03 GM# 22690562 2.2 Electrical Alternator 2.2L - 02-03 GM# 22583070 Starters 2.2L - 02-03 GM# 104465551 AC Compressor 2.2L - 02-03 GM# 22688565 2.2 & 2.4L -- belts & pulleys http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/beltspulley2.jpg 1 Serpentine Belt - 99-01 GM# 24576787 - 02-03 GM# 24466972 2 Belt Tensioner - 99 GM# 24575670 - 00-01 *Included with mount bracket - 02-03 GM# 24430296 3 Mounting bracket - w/o tensioner 99 GM# 24573852 - w/tensioner 00-01 GM# 24575354 Cooling syst continued 2.2- 2.4 Radiator support http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/radiatorsupport2.jpg 1 Upper bar - 99-03 GM# 22625808 2 Reinforcement = -99-03 GM# 22608916 3 Lower Panel - 99-03 GM# 22602298 Splash Shields http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/4cylsplashshileds.jpg Engine 1 -Outer, auto trans - 99-03 R GM# 22654880 - 99-03 L GM# 22654879 Outer, Manual trans - 99-03 R GM# 22654880 - 99-03 L GM# 22620385 2 -Lower - 99-03 GM# 22599670 Air inlet shield 3 -Upper - 99-03 GM# 22619965 4 -Lower - 99-03 B GM# 22620961 Radiator & Components http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/Radcomponents2.jpg 1 -Radiator Manual Trans - 99-01 GM# 52477426 4 speed - 02-03 GM# 52487242 5 speed - 02-03 GM# 22666459 AUTO trans - 99-01 GM# 52477425 - 02-03 GM# 52487242 2 Mounting bracket - 99-03 R GM# 22608986 - 99-03 L GM# 22608985 3 Lower Insulator - 99-03 B GM# 22597744 4 Outer seal - 99-03 Not serviced 5 Upper seal - 99-03 GM# 22636974 6 Reservoir tank - 99-01 GM# 22688945 - 02-03 GM# 22688945 Inlet Hose - 99-03 GM# 22622876 Overflow hose - 99-01 GM# 22602412 - 02-03 GM# 22628360 7 Reservoir Cap - 99-01 GM# 22652695 - 02-03 GM# 22628360 8 Level Sensor - 99-03 GM# 22565474 Radiator Hoses 2.4 L http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/RadHoses2.jpg 1 -Upper Hose - 99-01 GM# 22593999 2 -Lower Hose - 99-01 GM# 22645555 3 -Outlet Pipe w/o fitting - 99-01 GM# 24574380 w/ fitting - 99-01 GM# 24576122 4 Thermostat - 99-01 GM# 24577288 5 seal - 99-01 GM# 24577118 6 Water Outlet - 99-01 GM# 24575259 7 seal - 99-01 GM# 24572538 8 Mount bolt - 99-01 GM# 115157558 9 Clamp - 99-01 GM# 12338017 2.2 L Rad. hoses http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/RadHoses2-1.jpg 1 -Upper Hose -02-03 GM# 22680934 2 -Lower Hose - 02-03 GM# 22621759 3 -Outlet Pipe - 02-03 GM# 24447273 4 -O-Ring - 02-03 GM# 90537379 5 -Thermo Cover - 02-03 GM# 24447272 6 -Retainer - 02-03 GM# 24477777 7 -Seal - 02-03 GM# 3522676 8 -Thermostat - 02-03 GM# 21028811 9 -Seal - 02-03 GM# 24422922 10 -Thermostat Housing - 02-03 GM# 24447804 11 -Seal - 02-03 GM# 90537471 12 -By-Pass valve - 02-03 GM# 24465911 13 -reatiner - 02-03 GM# 24447276 14 -Seal - 02-03 GM# 24447275 Cooling Fans 2.2-2.4 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/RadFans2.jpg 1 -Fan - 99-03 GM# 12362564 -nut - 99-03 GM# 12362590 2 -Motor - 99-03 R GM# 88986473 - 99-03 L GM# 88986474 3 -bolt - 99-03 GM# 22062547 4 -Shroud Assy - 99-03 GM# 12362571 5 -Mount bracket - 99-03 R GM# 12362567 - 99-03 L GM# 12362568 6 -Shield - 99-03 GM# 22647113 7 -bolt - 99-03 GM# 11509428 -Fan Relay 4 pin - 99-03 GM# 12193604 5 pin - 99-01 GM# 12193602 - 02-03 GM# 12177234 -Temp sensor - 99-01 GM# 12146312 - 02-03 GM# 15326388 -Connector - 99-03 GM# 12101899 3.4 Cooling System Radiator supports http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/Radiatorsupportv6.jpg 1 - upper ite support - 99-03 GM #22625808 2 - Reinforcemnet - 99-03 GM #22608916 3- Air baffle - 99-03 GM #22616634 4 - Lower deflector - 99-03 GM #22602298 Splash shields http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6splashshields.jpg 1 -engine outer auto trans - 99-03 R 22654880 - 99-03 L 22654879 2 -Lower - 99-03 22599670 Air inlet shield 3 -Upper GT - 99-03 22619961 SE - 99-03 22619965 4 -Center GT - 99-03 22647827 5 -Side SE - 99-03 B 22620961 Radiator Components http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6Radcomponents.jpg 1 -Radiator --Manual trans -- 00-03 GM# 52477426 --Auto trans -- 99-01 GM# 52477425 -- 02-03 GM# 22676953 2 - Mount bracket - 6 -Resivour Tank - 99-01 GM# 22688945 - 02-03 GM# 22688945 Overflow Hose - 99-01 GM# 24505865 - 02-03 * part included in resivour tank 7 -Resivour Cap -- 99-00 GM# 22652695 -- 01-03 GM# 22671020 8 -Level Sensor -- 99-03 GM# 22565474 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6Radhoses.jpg 1 - Upper 99-03 GM# 22680642 2 -Lower hose 99-03 GM# 22647232 3 -Thermostat 99-03 GM# 24507563 4 -Thermo gasket 99-03 GM# 10226107 5 -Water Outlet(thermostat housing) 99-03 GM# 10182384 6 -mount bolt - 99-03 GM# 11508476 7 -clamp - 99-03 GM# 12338017 Cooling Fans http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6Fans.jpg 1 -Fan - 99-03 B GM# 12362564 2 -motor - 99-03 R GM# 88986473 - 99-03 L GM# 88986474 3 -bolt - 99-03 GM# 22062547 4 -Shroud Assy - 99-03 GM# 12362571 5 -mount bracket - 99-03 R GM# 12362567 - 99-03 L GM# 12362568 6 -Shield - 99-03 GM# 22647113 7 bolt - 99-03 GM# 11509428 Fan relay 4 pin - 99-03 GM# 12193604 5 pin - 99-01 GM# 12193602 - 02-03 GM# 12177234 -Temp Sensor - 99-01 GM# 12146312 - 02 GM# 15326386 - 03 GM# 12146312 -Connector- - 99-03 GM# 12101899 Belts & Pulleys http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6beltpulley.jpg 1 -Serpentine Belt - 99-01 GM# 12569376 - 02-03 GM# 12569376 2 - Belt Tensioner - 99-03 GM# 12563083 3 -Idler pulley - 99-01 GM# 24506756 - 02-03 GM# 12563097 4 -Shield - 99-01 GM# 24505681 - 02 GM# 12573679 - 03 GM# 12568396 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6waterpump.jpg 1 -Water Pump - 99-03 GM# 12371989 2 -Gasket - 99-03 GM# 10182374 3 -Pulley - 99-03 GM# 14091833 AC & Heater http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6Condensercompressorlines.jpg Condensor Compressor & Llines 1 -Condenser - 99-01 GM# 52495849 - 02-03 GM# 22663025 2 -tube to Evap - 99-01 GM# 22653160 - 02-03 GM# 22661508 3 -To drier w/o manual controls - 99-02 GM# 22603649 w/ manual controls - 99-03 GM# 52458768 4 -Clip - 99-03 GM# 22649287 5 -Hose & tube assy - 2.4 L - 99-01 GM# 22611604 - 2.2 L - 02-03 GM# 22681633 - 3.4 L - 99-01 GM# 22612151 - 02 GM# 22661448 - 03 Not listed 6 -Dehydrator - 99-01 GM# 1132770 - 02-03 GM# 1132777 7 -Insulator - 99-03 GM# 22637437 8 -bracket - 99-03 GM# 22593996 9 -Compressor 2.4L - 99-01 GM# 1135439 2.2L - 02-03 GM# 22688565 3.4L - 99-01 GM# 1135440 - 02 GM# 1135440 - 03 Not Listed -Bolt- 2.4L front - 99-01 GM# 10044389 rear - 99-01 GM# 11516366 2.2L -02-03 GM# 11519177 3.4 L upper - 99-03 GM# 24503610 Lower - 99-03 GM# 24503609 -Spacer - 3.4L - 99-03 GM# 10166385 -Pulley - 3.4L - 99-01 GM# 24506756 - 02 GM# 6580037 - 03 Not listed http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/HVACcomponents.jpg Evaporator & Heater Components 1 -Air inlet - 99-02 GM# 52481650 2 -Defrost duct - 99-02 GM# 52473696 3 -Evap core - 99-02 GM# 52474457 4 -Seal - 99-02 GM# 52486388 5 -bracket - 99-01 GM# 52480085 6 -filter - 99-02 GM# 3096022 7 -retainer - 99-02 GM# 3092246 Case 8 -upper - 99-02 GM# 52495744 9 -Lower - 99-02 GM# 52491731 Valve 10 - Defrost - 99-02 GM# 52481016 11 - AC - 99-02 GM# 52481609 Actuator 12 -Defrost valve - 99-01 GM# 52477455 - 02 GM# 5287754 13 -AC - 99-02 GM# 52478894 14 -Vacum tank - 99-02 GM# 52470570 15 -Heater Core - 99-02 GM# 52481264 16 -Seal - 99-02 GM# 22650205 Case 17 -Upper - 99-02 GM# 52470742 18 -Lower - 99-02 GM# 52491732 -Seal 19 -Case - 99-01 GM# 52464137 - 02 GM# 52489451 20 -Mounting - 99-01 GM# 52454645 - 02 GM# 52479798 Valve 21 -Heater - 99-02 GM# 52484819 22 -temp control - 99-02 GM# 52473890 Actuator 23 -Temp control - 99-02 GM# 16177412 24 -air valve - 99-02 GM# 52477456 Ignition system 3.4L http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/V6ignitionsystem.jpg 1 -Ignition Coil - 99-02 GM# 10472401 2 Seal - 99-02 GM# 1989579 3 Ignition Module - 99-02 GM# 10489422 4 Bracket - 99-02 GM# 10473138 5 PCM - 99 GM# 9356741 - 00 GM# 9380717 - 01 GM# 9378702 - 02 GM# 9380717 Pcm bracket - 99-02 GM# 22657999 Electrical Alternator 3.4L - 99- GM# 10464424 - 00-03 GM# 10464465 Starters 3.4L - 99-00 GM# 10465459 - 01 GM# 10465519 - 02-03 GM# 10465542 Electrical Components http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/Electricalcomponents.jpg 1 junction(fuse) box - 99-00 GM# 15323499 1st design - 01-02 GM# 15356092 2nd design - 02 GM# 22686945 All - 03 GM# 22681985 2 Mount bracket - 99-03 GM#12564339 3 Cover - 99-03 GM# 15393899 4 Retainer - 99-03 GM# 12084709 5 Shield - 99-03 GM# 15319645 6 Label - 99-00 GM# 15328802 - 01 -02 GM# 15401192 - 03 GM# 88953162 7 Cover pos. battery cable - 99-03 GM# 12194094 8 Wire connector - black - 99-03 GM# 15303513 - brown - 99-03 GM# 15303514 - grey - 99-03 GM# 15303512 9 Connector wire - grey - 99-03 GM# 15305886 - black - 99-03 GM# 15305928 - neutral - 99-03 GM# 15305920 10 Fuel pump relay - 99-03 GM# 15393412 11 Relay - 99-03 GM# 12193604 12 Fuse - 99-03 GM# 12065932 13 Fuse puller - 99-03 GM# 1219790 More below...... xeroinfinity 01-18-2007, 05:15 PM Engine and Transaxle 2.2L http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-7.jpg Air intake 1 Air Cleaner Assy 02-03 GM# 22659983 2 Air filter 02-03 GM #25161977 3 Mount bracket -02-03 GM# 12564339 Support bracket 4 Upper - 02-03 GM# 22653408 5 Lower - 02-03 GM# 22599991 6 Front Duct - 02-03 GM# 12564515 7 Air Outlet duct - 02-02 GM# 22659985 8 Resonator - 02-03 GM# 22659984 Air Temp Sensor 02-03 GM# 12160244 2.2 Engine Parts http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-8.jpg 1 Crankshaft Balance 02-03 gm# 90537704 2 Timing cover 02-03 GM# 24450057 3 Gasket 02-03 GM# 2442669 4 Seal 02-03 GM# 90537704 5 Valve Cover 02-03 GM# 24426069 6 Gasket 02-03 GM# 90537319 7 Filler Cap 02-03 GM# 12573342 8 Seal 02-03 24100002 9 Oil Pan 02-03 GM# 24406361 10 Baffle 02-03 GM# 24406368 gasket 02-03 GM# NL 11 Oil Filter 02-03 GM# 24460712 12 Dip stick 02-03 GM# 24428553 13 Tube assy 02-03 GM #2440078 2.2 Transaxle Parts http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-9.jpg Transaxle Parts 1 - Trans Pan 02-03 GM# 8685184 2 - Gasket 02-03 GM# 24203590 3 - Filter 02-03 GM# 24221762 4 - magnet 02-03 GM# 8665830 2.2 Engine Mounting http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-10.jpg 1 Motor Mount 02-03 GM# 22696931 2 Adapter 02-03 GM# 22676701 Trans Mount 3 Front - manual trans 02-03 GM# 2604369 - auto trans 02-30 GM# 22621543 4 Rear - manaul trans 02-03 GM# 22604370 - auto trans 02-03 GM# 22624648 5 Side - Manual trans 02-03 GM# 22604371 - auto trans 02-03 GM# 22590932 Trans Mount Bracket 6 Front 02-03 GM# 22614831 7 Rear 02-03 GM# 22659448 8 Block to trans 02-03 GM# 24450984 Heatshield 02-03 GM# 22649030 Engine and Transaxle 2.4L http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-11.jpg Air box 1 Air Cleaner Assy 02-03 GM# 25171392 2 Cover - 99-01 included with air cleaner assy 3 Air Filter 02-03 GM# 25161977 4 Housing - 99-01 included with air cleaner assy 5 Insulator - 99-01 included with air cleaner assy 6 Rear duct - 99-01 included with air cleaner assy 7 Mount bracket - 99-01 GM# 12564339 Support bracket 8 upper - 99-01 GM# 22653408 9 Lower - 99-01 GM# 22599991 10 Front duct - 99-01 GM# 12564515 11 Air outlet duct - 99-01 GM# 24574954 12 Resonator - 99-01 GM# 24574953 13 Air Temp sensor 02-03 GM# 12160244 Clamp 14 front - 99-01 GM# 10087567 15 Center - 99-01 GM# 22542761 16 Rear - 99-01 GM# 10087567 17 Resonator - 99-01 GM# 24575547 18 Seal - 99-01 GM# 24575644 19 Clamp - 99-01 GM# 12338017 20 bracket - 99-01 GM# 24574538 Engine Parts 2.4 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-12.jpg Engine Parts 1 Crankshaft Balance 99-01 GM# 24575562 2 Tming Cover 99-01 GM# 24576620 Gasket 3 Outer 99-01 GM# 24575243 4 Inner 99-01 GM# 24574584 5 Oil Seal 99-01 GM# 22531277 6 Inner Housing Timing Chain 99-01 GM# 24576060 7 Filler Cap 99-01 GM# 93439687 8 Cam Housing Intake cam w/cover 99-01 GM# 24574056 exhaust cam w/cover 99-01 GM# 24573741 9 Gasket intake w/cover 99-01 GM# 12363173 exhaust w/cover 99-01 GM# 12355988 10 Dip Stick 99-01 GM# 24574970 11 Tube Assy 99-01 GM# 24574160 12 Oil Pan 99-01 GM# 24574970 13 Gasket 99-01 GM# 24574406 14 Oil Filter 99-01 GM# 25010633 Transaxle Parts 2.4 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-13.jpg Transaxle Parts Auto : 1 FlyWheel 99-01 GM# 24575970 2 bolt GM# 25509226 3 Coverter 99-01 GM# 24211330 4 Cover 99-01 GM# 24574011 5 Trans Pan W/O Gasket 99-01 GM# 8685184 W/Gasket 99-01 GM# 24203769 6 Gasket 99-01 GM# 24203590 7 Filter 99-01 GM# 24221762 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-14.jpg Manual: 1 Flywheel 00-01 GM# 22533244 2 Clutch 00-01 GM# 22622114 3 Pressure Plate 00-01 GM# 22629291 4 Cylinder Clutch Master Cyl 00-01 GM# 22632982 Cover 5 Front 00-01 GM# 22613826 6 Rear 00-01 GM# 22613827 Engine Mounting 2.4 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/2-15.jpg Engine Mounting 1 Motor Mount 99-01 GM# 22657322 2 Adapter 99-01 GM# 22608899 Trans Mount 3 Front 99 GM# 22605204 - Manual trans 00-01 GM# 22604369 - Auto trans 00-01 GM# 22605204 4 Rear 99 GM# 22624648 - Manaul trans 00-01 GM# 22604370 - Auto trans 00-01 GM# 22624648 5 Side 99 GM# 25590932 - Manual trans 00-01 GM# 22604371 - Auto trans 00-01 GM# 22590832 Trans Mount Bracket 6 - Front 99-01 GM# 22614831 7 - Rear 99-01 GM# 22659448 8 - Block to trans 99-01 GM# 24575222 Heat Shield 99-01 GM# 22649030 Engine And Transaxle 3.4L http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/3-2.jpg Air Assy 1 Air Cleaner Assy -W/O Ram Air 99-03 GM# 25177520 -W/Ram Air Package 99-03 GM# 25177519 2 Cover *included with air cleaner assy 3 Air Filter 99-03 GM# 25161977 4 Housing * included with air cleaner assy 5 Insulator *included with air cleaner assy 6 Rear Duct included with air cleaner assy 7 Mount bracket - 99-03 GM# 12564339 Support bracket 8 upper - 99-03 GM# 22653408 9 lower - 99-03 GM# 22599991 Air duct 10 upper w/Ram air package - 99-03 GM# 24507995 11 Lower - 99-02 GM# 12563826 12 Seal w/Ram air package - 99-03 GM# 24508234 13 Adapter - 99-03 GM# 25099500 14 Air Mass Sensor(MAF) 99-03 25180303 15 Clamp - 99-03 GM# 24505503 16 Air Temp Sensor(IAT) 99-03 GM# 12160244 17 PCV Tube - 99 GM# 24504646 - 00-03 GM# 24508188 18 Air duct(between TB and MAF) 99-03 GM# 24505502 19 Clamp - 99-02 GM# 10087567 - 03 GM# 24508399 Engine Parts 3.4 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/3-3.jpg Engine Parts 1 Crankshaft balance 99-03 GM# 24504609 2 Timing Cover 99-03 GM# 24505667 3 gasket 99-03 GM# 10189276 4 Oil Seal 99-03 GM# 10243247 5 Oil Pan 99-03 GM# 12512670 6 gasket 99-03 GM# 10182387 7 Baffle 99-03 GM# 24503912 8 Oil Filter 99-03 GM# 25010792 9 Oil Level Sensor 99-03 GM# 24506885 10 Vavle Cover - 99-02R GM# 24504670 - 99-02L GM# 24504669 - 03 R GM# 24504670 - 03 L GM# 12575018 11 Gasket 99-03 B GM# 10154775 12 Fller Cap 99-03 GM# 21007373 13 Dip Stick - 99-02 GM# 12574894 - 03 GM# 12574894 14 Tub Assy - 99 GM# 10236994 - 00-03 GM# 24507976 Trans axle Parts http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/3-4.jpg 1 Flywheel 99-03 GM# 24576876 2 bolt 99-03 GM# 12338144 3 Converter 99-03 GM# 24211330 4 Cover - 99-03 GM# 24507882 5 Trans Pan - W/O gasket 99-02 GM# 8685184 - W/gasket 99-02 GM# 24203769 All 03 GM# 8685184 6 Gakset 99-03 GM# 24203590 7 Filter 99-03 GM# 24221762 Engine Mounting 3.4 http://i28.photobucket.com/albums/c242/xeroinfinity/fisslesticks/3-5.jpg Engine Mounting 1 Motor Mount 99-03 GM# 22657322 2 Adapter 99-03 GM# 22692941 Trans Mount 3 Front - 99-03 GM# 22605204 4 Rear - 99-03 GM# 22624648 5 Side - 99-03 GM# 22590932 Trans Mount brisket 6 Front 99-03 GM# 22614831 7 Rear 99-03 GM# 22659448 Trans Support 8 Upper 99-03 GM# 22652765 9 Lower 99-03 GM# 22653988 More On Part 2 starting with Emission Components Automotive Network, Inc., Copyright ©2012
