Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 01-15-2007, 11:50 AM   #1
2001 ASTRO DUDE
2001 ASTRO DUDE Normal reputation
black box question
I just replaced the fuel pump assembly on my 2001 Astro this weekend. As I was dropping the tank I noticed a small black box mounted on the frame rail with an electrical lead a (2) different sizes of plastic fuel lines running from it to the top of the tank. After lowering the tank, I noticed this large black box mounted to the top of the tank. There were the (2) lines I already mentioned connected to it. Does anyone have any clue what this magic black box is for? My only guess is some kind of interface to the diplay mounted on the overhead console for the fuel milage ect. Fuel pump replacement went fairly well but I could not beleive the pump assembly was $299.00!!!!
2001 ASTRO DUDE is offline   Reply With Quote
Old 01-16-2007, 03:26 PM   #2
drew300
drew300 Normal reputation
Re: black box question
When I replaced my pump on a '97, I don't have a black box.
But GM service wanted $860.00 Canadian for it, in a box, not installed. I found an after-market one, best price was $460.00.....
drew300 is offline   Reply With Quote
Old 01-17-2007, 10:44 AM   #3
brcidd
brcidd's Avatar
brcidd Normal reputation
That would be your evaporative canister
Evaporative Emission Hoses/Pipes Replacement - Canister/Fuel Tank
Removal Procedure
Remove the fuel tank. Refer to Fuel Tank Replacement .
Disconnect the EVAP vapor pipe (5) from the EVAP canister (1).
Disconnect the EVAP vapor pipe from the fill limiter vent valve (2).
Remove the EVAP vapor pipe.
Installation Procedure
Connect the EVAP vapor pipe (5) to the fill limiter vent valve (2).
Connect the EVAP vapor pipe to the EVAP canister (1).
Install the fuel tank. Refer to Fuel Tank Replacement .
brcidd is offline   Reply With Quote
Old 01-17-2007, 12:20 PM   #4
2001 ASTRO DUDE
I found my replacement pump assembly (in the box) at Autozone here and it was $299 US dollars. So you are saying that this rectangular black box mounted on top of the fuel tank is the evaporator canister? Other vehicles have these mounted under the hood to the fender well or firewall . This box mounted to my tank has a large ans a small plastic fuel lines with the quick disconnect fittings on it. Both lines run to a smaller black box with a wiring harness attached. Why would an evaporator canister need an electrical connection??? I have the optional computer system in the overhead console that has the compass, fuel milage, and fuel consumption/milage remaining display. This would make more sense to me than the canister. Nothing is wrong with it but I just wanted to find out what the hell it was .
Old 01-18-2007, 06:59 AM   #5
brcidd
brcidd's Avatar
The description I gave you is a cut and paste from the GM service manual- the diagrams did not paste though, the electrical connections to an evap canister would be for the solenoid valve that can open or close depending on fuel tank pressure or the purge routine. The diagrams clearly show the evap canister mounted on top the tank................
Old 01-18-2007, 01:49 PM   #6
2001 ASTRO DUDE
Thanks for clearing up the mystery. My haynes manual did not show anything about this at all so I was a bit puzzled when I started dropping the tank.
Bookmarks
Google
Web AF
