Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 01-14-2007, 09:48 PM   #1
Getgot2112
Getgot2112 Normal reputation
1999 Cavalier Mis Fire
Hello, just joined up today. Have a 1999 Cavalier that I bought for my daugher. About 3 weeks ago I took it in and had new plugs, new coil pack and new wires installed. Today I can tell that it is mis firing again and the check engine light is on.
I un plugged each plug and then plugged them back in to make sure good connection. Then I un plugged each wire from the coil pack and plugged them back in. Making sure I did not mix up the order.
At one point in time in this process I started the car and the check engine light started to blink but the engine was running fine again. After shutting the hood, the check engine remained on and the mis firing started again.
Was just wondering if the plug wires were installed to the proper location on the coil pack? Does anyone know the order that the wires should be connected?
Thanks
Getgot2112 is offline   Reply With Quote
Old 01-15-2007, 03:50 PM   #2
rconeal
rconeal Normal reputation
Re: 1999 Cavalier Mis Fire
I have a 1995 2.2 From the passanger side of the engine plugs are 1234 but the coil packs are 4132
rconeal is offline   Reply With Quote
Bookmarks
Google
Web AF
