No Overdrive, delayed shift 98' Cherokee 4.0Lmailman30808 01-14-2007, 06:01 PM My 98' Cherokee won't shift from first gear into second until it runs to warm up for a few minutes, after that it shifts fine. The other problem is that the Overdrive went out. It shifts through all of the gears, the converter locks up as it should but it won't go into overdrive. The "Check Engine" light is on and it does show several tranny trouble codes, but where should I start? AlohaBra 01-14-2007, 07:18 PM Get the codes if you can....it is probably the NSS. mailman30808 01-14-2007, 07:23 PM I have already checked and cleaned the Neutral Saftey Switch, didn't fix the problem.... AlohaBra 01-14-2007, 10:04 PM What are the codes? mailman30808 01-15-2007, 11:17 PM I will check them again when I get off of work tomorrow. I delliver mail and have a scanner so I will connect it while I'm on the route and see if it pulls any more codes. Automotive Network, Inc., Copyright ©2012
