Originally Posted by paulierizzo
i have a 1999 blazer i bought and the key always worked hard one day security light came on and now i cant start truck, i read post and replaced ignition switch --no help-- waiting for key lock cyliner to come in to see if that will fix it. does anyone have idea or no if i will have to do someing after lock is installed? clear codes/relearn key. been over two weeks messing with it and need it fixed thanks
First thing you need to get a engine\body capable scanner on it and get the body code no.
Post back code no.
It will point you to the problem.
Des started turn over engine?
Does engine start and run 30 seconds.
Any horn or lights flashing?
Two different security systems are used.
Do you know which one you have?
Try leaving key on for 20 minutes and see if it will over ride system.
