no fuel in fuel lines w/ new pump
Vlad_907
01-12-2007, 02:24 PM
I have a 95 Voyager SE, its got a 3.3 liter in it and i recently switched the fuel filter, fuel pump and im still not getting gas up to the engine. I would apreciate anyones info on what may be going on. I disconected the fuel lines from the gas tank just to see if there were fuel pumping out of the tank but its not even doing that. So Anyone?
KimMG
01-12-2007, 03:31 PM
Are you getting power to the fuel pump?
Vlad_907
01-12-2007, 03:54 PM
yes I can hear the pump turn on every time i turn the key halfway
1thunder
01-12-2007, 06:50 PM
crank engine over and check for power at the green/red tracer wire at the connector at the left rear outboard side of the frame just ahead of the fuel tank you have to get battery voltage on a crank if a crank or cam sensor fails you wont get any voltage there when cranking you may have heard the pump when cycling the key but the program in the pcm only allows this a few times then will not cycle the pump untill it sees a engine revolution you can also jump the fuel pump relay in the pdc fuse box under the hood just remove the relay and check under the relay pin# are printed there jump pin 30 to pin87 make sure you dont jump to 87A wich is the center pin this will confirm if the pump does actually work
Vlad_907
01-13-2007, 06:19 AM
thanks for the info. ill give it a try see what happens
