Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 01-12-2007, 09:24 AM   #1
240SX_89
240SX_89 Normal reputation
Angry 97 GMC Safari wont start.
This morning I tried turning on the van but it wouldnt start. It happen last week but I had a mechanic take a look at it but he said nothing was wrong with it. When he got it to his shop it started up with out any problems. When I brought it home it was working fine but now its having the same problem. After trying to turn it on I noticed that it smells like gas. The smells comes from the rear drivers side.
240SX_89 is offline   Reply With Quote
Old 01-13-2007, 07:19 AM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
GMMerlin Normal reputation
Re: 97 GMC Safari wont start.
Check spark,fuel pressure.
Look closely at the coil wire and the cap and rotor on those.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 01-16-2007, 04:40 PM   #3
drew300
drew300 Normal reputation
As my '97 fuel pump got weak, it would cold start on starting fluid, but then ran fine, and would start when warm.
A quick spray of carb cleaner or so would tell you if it's a spark problem, or a fuel pressure problem.
To start, a GM service rep told me " minimum 60" psi. I had 59, but that wasn't good enough.
drew300 is offline   Reply With Quote
Old 01-16-2007, 04:49 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
If you smell fuel: Check fuel pressure while the pump is running, as Drew300 mentioned, 60psi MINIMUM. After the pump shuts down, (approximately 3 seconds) watch for leakdown. Pressure should not drop below 55 psi. If it does, you have a leak somewhere.
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
